Surplus to requirements now.
its been fitted to my car for about 10 years, but has only had 4 refills in that time (so about 20 minutes total use!)
comes with :-
Twin injectors and all the distribution blocks and piping from the Pulsoids (I think the pulsoids have a lifetime warranty)
Injectors currently fitted into 2 alloy hs4 spacers.
5lb bottle + mount
Pulsoids on mounting plate
arm switch that bolts to gearstick
throttle switch.
Fuel pipe t-piece.
a number of new olives for the 2 different sized delivery lines used.
WON book.
Some WON Stickers for your Windows for the adulation of your peers!
you would need to buy some of the larger bore fuel and Nitrous pipes from WON depending on where you want to fit the bottle. You will also need to make up your own wiring - again depending on where you fit everything.
the kit can easily be converted back to single-injector- if I can find the hif44 spacer I will include it too.
It can also easily be changed to run on ANY carbed car.
25bhp jets currently fitted.
more pictures can be supplied if requested.
Everything is in Edinburgh Scotland, but can be brought to the L2B or the IMM (or posted).
£300 ono. No Swaps
Due to issues with people and paypal, Cash is preferred - paypal would have to be as a gift (sorry - but too many people have f**ked me about selling motorbike bits using paypal)
