Page: |
Home > Non-Mini Discussion > Who can confirm my suspicion about my ducato | |||||||
1750 Posts Member #: 10190 Post Whore belgium |
23rd Mar, 2017 at 03:08:46pm
Maybe first the story that leads to my suspension.
2909 Posts Member #: 83 Post Whore Glasgow, Scotland |
23rd Mar, 2017 at 03:35:54pm
Your theory doesnt hold up. Never something i have experienced. More likely its going into limp mode due to a shite remap, or vnt sticking or egr sticking but thats just speculation.
23rd Mar, 2017 at 05:23:51pm
The remap has been done 12 months ago. Didnt have that before. Zgr is out of the car because they didn't work proper and are in no need with the remap. What is vnt? you can do anything if you set your mind to it...
971 Posts Member #: 3228 Post Whore North of the Netherlands |
23rd Mar, 2017 at 06:16:08pm
Don't know how the VNT is operated but if it is done by vacuum?
Dazed and Confused.... |
23rd Mar, 2017 at 07:10:08pm
Vacuum operated indeed. Hm ill check. Shitty thing to work on and so daim italian. There is always something broken. ( yet engine is a ford... ) you can do anything if you set your mind to it...
23rd Mar, 2017 at 10:28:28pm
sorry origional post read that remap was done then symtoms started. as its the ford engine, is the egr actualy removed or just disconnected? if its still connected it could be open a bit. depending on age vnt is vacuum operated or electrically operated. electic actuators fail, but it flags up warning lights too (normally bu yours are disabled) if its the earlier vacuum actuator it tends not to fault but the vaccum lines can, the vacum supply can fail/be blocked. and finally carbon build up in the vnt mechnaism can prevent it moving its full range causing driviability issues. turbo 16v k-series 11.9@118.9 :)
23rd Mar, 2017 at 10:52:13pm
Okey. Some things to look at. Just glad its not the turbo. They said removed but.... you can do anything if you set your mind to it...
23rd Mar, 2017 at 11:04:27pm
Maybe important to add... it always comes up when driving slow reves for a while or when running near stationery for some time ( in heavy traffic ) you can do anything if you set your mind to it...
24th Mar, 2017 at 09:59:27am
id check the vnt for stickyness then enlist the help of a good garage with diagnostic stuff if you know anyone. turbo 16v k-series 11.9@118.9 :)
3588 Posts Member #: 655 Post Whore Northern Ireland |
24th Mar, 2017 at 10:59:12am
Although if the idiots re-mapping have deleted the ecu's ability to recognise and report some faults...who know what else they deleted in there.
109 Posts Member #: 10368 Advanced Member Australia |
24th Mar, 2017 at 11:23:27am
Might be useful, but may not be
24th Mar, 2017 at 05:24:49pm
Drove it with a diagnose computer on the plug today 50 km in total... guess what. The orange bitch didnt even give a hickup. Have it for the weekend. So who knows what will come up. you can do anything if you set your mind to it...
25th Mar, 2017 at 09:14:55pm
dont you hate intermittent problems. On my Daily ( Iveco) if the ECU 'thinks' there is a problem then the electronics keep the warnings coming even if fault rectified itself. Sometimes 30 minutes away from the car lets those memory warnings settle down. |
26th Mar, 2017 at 09:07:19am
The thing i most hate about this truck is that if it gives a warning its usually gone by the time you get to the garage. It should have a diagnose computer with a 24 hour memory build in... anyway just returned the diagnosis computer of my friend. Went into limp mode once for about 3 seconds then started pulling again but it gave no fault to the computer. To short of time? Its like it new it had a computer on so should behave better... you can do anything if you set your mind to it...
26th Mar, 2017 at 10:16:57am
As said, you need someone able to monitor and review the live data to see when/why it is throwing up any faults.
26th Mar, 2017 at 09:13:34pm
Its one of the best know here. Remaps everething from ferrari to mobilhomes. But do know he had big big trouble with mine. They said 3 hours... became 3 days. you can do anything if you set your mind to it...
Page: |
