Page: |
Home > Technical Chat > MPI cover engine | |||||||
7 Posts Member #: 11392 Junior Member |
21st Mar, 2017 at 09:08:22pm
What do I have to do to the block to turbo it
4625 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
21st Mar, 2017 at 09:17:12pm
You don't have to do anything in particular to the block itself. You ideally need to consider fitting some better pistons than the standard ones unless you plan on keeping the boost conservative.
11046 Posts Member #: 965 Post Whore Preston On The Brook |
21st Mar, 2017 at 09:31:16pm
need to figure out how to return the oil to the sump.
21st Mar, 2017 at 09:33:35pm
Good call Col ! Never thought about that. What about as high up on the gearbox casing as possible ? I'm pretty sure Jimster ? Had his like this at some point.
Edited by Turbo Phil on 21st Mar, 2017. |
22nd Mar, 2017 at 05:55:05am
What about the cam shaft? |
2094 Posts Member #: 9894 Post Whore Dorking |
22nd Mar, 2017 at 03:45:49pm
All depends on what you want from the car.
53 Posts Member #: 10528 Advanced Member Denmark |
22nd Mar, 2017 at 06:45:48pm
On my MPI the oil return is fitted in the top of the gearbox - as the hole for the cam sensor sits to high... |
22nd Mar, 2017 at 06:53:56pm
as above the oil drain is the biggest issue,
167 Posts Member #: 11091 Advanced Member |
24th Mar, 2017 at 07:40:12pm
Oil drain can go to the camshaft hole but is tight
Page: |
