Home > General Chat > Fixing thingys...
evad1980
Member #: 10165
Stansted, Essex
Greetings..
I have an intercooler set up and now woking on air filter piping and routing... the thing is, as I'm using alloy tube with silicone bends I have nowhere to fix all the piping to. Its all a bit wobbly when moved by hand.. just after a few ideas really a how to make them fairly solid by fixing somehow.. preferably without looking rough if I can..
Any thoughts?
Don't try to nail it down too much. The engine will move and the pipes will expand a little on a decent amount of boost. Allow it to move a little without flopping about. Mount the intercooler to something then work back.
evad1980
Member #: 10165
Stansted, Essex
Yeah looking at how to mount the intercooler also.. I was even toying with the ideas of jubilee clips at various locations on the pipework fixed somewhere? Cant imagine that though looking decent...
What about large P clips?
D4VE
Member #: 10749
lowestoft suffolk
Your intercooler has the tabs on the bottom.. can u not weld up some round bar for it to sit in
Nothing gets past Dave lol
You could if the intercooler sits in the right place fix straps/brackets to the head studs. That way the intercooler moves with the engine, reducing the chance of boost hoses moving or coming off.
Never mounted the pipes always the intercooler. As tom says start there and work your way back.
evad1980
Member #: 10165
Stansted, Essex
Ok chaps thanks.. all good ideas. I'll somehow get the intercooler fixed in place then take it from there.
what cooler you going with?
evad1980
Member #: 10165
Stansted, Essex
From an RS turbo Rob, it's on my build thread... same as this one...
https://www.ebay.co.uk/itm/182227707175
