Home > 998cc > Which Valve springs?
steve2016
Member #: 11403
Looking for some valve springs for my 295 head as the current ones some are longer than the others!
Would these be OK?
http://minispares.com/product/classic/C-AEA526.aspx
Or
http://minispares.com/product/Classic/Engi...k%20to%20search
Or is there any others to look at?
Thanks
What cam/rockers ?
Phil.
steve2016
Member #: 11403
Either mg metro cam or 266 and stock 998 rockers thanks
C-AEA525 will do fine.
Phil.
steve2016
Member #: 11403
Thanks, would I not gain anything from the C-AEA526 set or will they be to strong ?
You won't gain anything running more spring pressure than you need.
Phil.
steve2016
Member #: 11403
Thanks I will go with that set then
