Home > Beginners Tech > No dump valve ?
minimauritius
Member #: 10545
MAURITIUS
Is it okay to run without a blow of valve on reasonable boost like less than 10 psi ? Don't think the metro had one anyway.
Thanks
yeah eapecially if your on the t3 as they are pretty durable.
minimauritius
Member #: 10545
MAURITIUS
Would the standard setup be less prone to surge because the butterfly is closer to the turbo comparing to all the piping for an intercooled one?
Are people getting strong noise from their BOV on standard setup ?
At 10psi on a small turbo it's noticeable inside the car, but not outside
I ran my clio at 0.6 bar no dv for 60k on the same turbo.
JT
Member #: 637
Hertfordshire
Would it be OK to run no dump valve with a high boost gt17?
My build thread..
I really wouldnt, the gt17 althogh a great turbo, has a pretty thin shaft, and Ive head of them shearing on high boost stuff.
JT
Member #: 637
Hertfordshire
I've got a cheap ebay universal dv. When I was running 20psi it would dump and flutter at the same time lol. The dv obviously couldn't dump enough at high boost.
I was wondering if I should get anther dv or just do away with it.
My build thread..
is the DV before or after the intercooler?
personaly I dont like these DV's with a ring of smaller holes (6mm?) personally i run a recirc one, but without the recirc connected, i havent checked but i suspect one 1" hole flows better than a bunch of small ones.
JT
Member #: 637
Hertfordshire
It's fitted on the plenum. It looks like a forge type dv.
My build thread..
JT
Member #: 637
Hertfordshire
Like this....
https://rover.ebay.com/rover/0/0/0?mpre=htt...%2F301847628452
My build thread..
if its a piston one pull it apart and check it all moves freely, the o ring on the piston can swell so they stick, diaghram ones seem more reliable.
hazpalmer
Member #: 9038
Carlisle, Cumbria
the standard bosch one is quite reliable isn't it? I got one of Dave from the A35 van. I think Colin uses one on his sprite to
the plastic R/angle one? yeah, good bit of kit.
D4VE
Member #: 10749
lowestoft suffolk
Can ya change spring in it? I have the one described with smaller holes but when it goes back on road it shall have the recirc valve just not plumbed in, like mentioned above
Edited by D4VE on 17th Apr, 2018.
Nothing gets past Dave lol
Ive found that if you havent got the vac pipe on the DV it'll actually open, at about 12-15psi on my one, it needs the boost there to keep it shut.
