Page: |
Home > Beginners Tech > thnx to Benross Joe C and PhilR pics of the end result up | |||||||
![]() 1750 Posts Member #: 10190 Post Whore belgium |
11th Jan, 2017 at 09:03:37pm
So i was thinking on what benross said about carbid bits. and then someone somewhere here i saw someone make a piston dish bigger with a router and then i also remember someone cutting the seats for under crown jets with a butterfly drill bit and saying he was amazed how soft grade the steel of the engine is... so it made me wonder about my wood bits for the router if it could cut a head. so i got an old head out took the router and a cheap wood bit... guess what. its like cutting to ( frozen) butter. so tommorow i will be making a mould and cutting my 1275 head to turbo use! Edited by Rammie2000 on 9th Mar, 2017. you can do anything if you set your mind to it...
167 Posts Member #: 11091 Advanced Member |
11th Jan, 2017 at 09:19:52pm
Pics please!
11th Jan, 2017 at 09:24:03pm
ill take pics of the result tomorrow. grts you can do anything if you set your mind to it...
11th Jan, 2017 at 09:34:38pm
Hah I suggested the router, glad it's working for you!
![]() 4629 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
11th Jan, 2017 at 10:13:29pm
Good luck. Hopefully it will be quicker and easier than using your dremel.
![]() 696 Posts Member #: 10034 Post Whore Birmingham |
11th Jan, 2017 at 10:40:14pm
Edited by PhilR on 11th Jan, 2017. |
11th Jan, 2017 at 11:52:09pm
Ha yes that was it!
12th Jan, 2017 at 10:30:35am
510 Posts Member #: 1592 Smart Guy! mainland europe near ze germans |
12th Jan, 2017 at 10:44:47am
Like this ? :)
12th Jan, 2017 at 10:59:57am
Aa yes. Apparently. Only not out of free hand. Would like to have them even in size. you can do anything if you set your mind to it...
![]() 644 Posts Member #: 9371 Post Whore East Yorkshire |
15th Jan, 2017 at 07:23:12am
This has surprised me.... excellent work Rammie. BHP sells engines, but Torque wins races! |
15th Jan, 2017 at 10:08:10am
Good work Rammie. That's much better than doing it freehand with a Dremel.
15th Jan, 2017 at 11:35:04am
On 15th Jan, 2017 PhilR said:
Good work Rammie. That's much better than doing it freehand with a Dremel. While a carbide bit would be more efficient, it would be interesting to grind a wood bit to a custom profile. Maybe one that cuts a shallower angle on the walls and another that cuts the floor flat, but has a very gradual radius into the walls. I've yet to find carbide bits that do this exactly how I imagine. you can do anything if you set your mind to it...
15th Jan, 2017 at 11:35:35am
On 15th Jan, 2017 madonminis said:
This has surprised me.... excellent work Rammie. you can do anything if you set your mind to it...
17th Jan, 2017 at 04:43:18am
Use a flat bottomed grinding stone ( a 20000 rpm rated one) that is well behaved for the floor. you can dress the stone to the desired profile if you want that. That sir, is not rust, it is the progressive mass reduction system
Forum Mod ![]() 1927 Posts Member #: 1761 Stalker Bristol |
17th Jan, 2017 at 01:37:23pm
This is great; ingenious solution to getting a repeatable pattern cut out of the chambers Edited by Carl S on 17th Jan, 2017. |
17th Jan, 2017 at 06:16:39pm
Working on a better mold so the result should be better 2. So all 4 can be grindee out without moving the mold. And thnx Edited by Rammie2000 on 17th Jan, 2017. you can do anything if you set your mind to it...
1st Mar, 2017 at 09:57:36pm
1st Mar, 2017 at 10:00:25pm
So did take some pics. Hahaha.
1st Mar, 2017 at 10:05:44pm
So placed the mold and fittet it with wood pieces that it sits realy tight on the head. Then used a drill trough the valve guides to centre out and painted the head to have a negative of it on the mold printed the form i wanted on a piece of paper copy it 4 times made the same centers on it gleud it onto the wood rechecked and cut it out with a dremel saw. Some sanding and here we go. The room between cambres on the mold is 4 mm thinner than it will be on the head ( the guide that follows it is 2 mm wider than the bit on the router guide plate) hope it makes sense in my crappie English. you can do anything if you set your mind to it...
1st Mar, 2017 at 10:16:58pm
2nd Mar, 2017 at 10:02:03am
brilliant! |
9th Mar, 2017 at 08:05:39pm
Page: |
