Home > For Sale > Job lot Gt1752 turbo build parts for sale
minicheckmatematty
Member #: 11483
Batley, west yorkshire
Unfortunately it has come the time to sell my turbo parts, i made a great start on collecting all the required parts for my turbo project but family came along and changed everything so i no longer have the need for these parts so i hope they can be of good use to someone and save you a lot of time hunting for parts like i did over a couple of years tracking all this lot down, there is a lot available if you are interested in it as a job lot please get in touch, my number is 07919 030353 many thanks Matty
Mpi Fuel Tank with fuel pump £120
Gt1752 Saab Turbo with exhaust manifold, was made as a mock up manifold not great welding as you can see from the pictures but does the job, £250
Mg Metro Turbo inlet manifold with pipes in tact and correct fitment for dump valve pipe £50
Rebuilt Hiff 44 carb 1.75" £150
Plenum £80
New Polished forge dump valve FMDV001GTI £80
New ASH silicone hoses + stainless steel T clamps £140
New braided fuel hose and fuel ends, you can see from the picture how they work with the fuel reg £40
Ford cosworth modifies inter cooler, with modified take off turned 90 degrees to work with the silicone hoses under the bonnet £80
Rebuilt gear box with mini spares cross pin diff, centre oil pick up and new layshaft washers £300
New omega lower compression pistons +0.20" 10cc dish £280
New ARP rod bolts 206 6002 £70
New Carbon fibre air filter £35
New single cone filter £10
New twin cone air filter £10
Rose jointed adjustable tie bars £100
Oil cooler pipes £20
Turbo bonnet/air scoop, fibre glass £10
Located in Batley, West Yorkshire any questions please get in touch on 07919 030353 many thanks Matty
minicheckmatematty
Member #: 11483
Forgot about the fuel regulator, New £35
Spenser8797
Member #: 11049
Kent
I'll have the intercooler please if you can post
tadge44
Member #: 2500
Buckinghamshire
I,ll have the twin cone filter please. Just PM me details of how you would like to be paid.
jeebz
Member #: 10189
Just dropped you a text about the gearbox
meghan746
Member #: 11498
I've private messaged you about a few bits :)
benspickup
Member #: 9608
Lincolnshire
Have you still got the turbo and manifold?
Is the turbo useable? Any wobble etc
Thanks Ben
