Page: |
Home > Show Us Yours! > Pickup K1100 build eventually | |||||||
15 Posts Member #: 10647 Member |
13th Dec, 2016 at 10:39:26pm
1030 Posts Member #: 1291 Post Whore Suffolk / Birmingham |
14th Dec, 2016 at 07:16:26am
Internal fuel pump and swirl pot is the neatest solution.
14th Dec, 2016 at 07:39:12am
Thanks for the reply. Yeh having the alloy tank made up with foams etc is a bit far at this point. I'm going to have a measure of the distance from underneath the subframe to the load bed might be able to squeeze a small swirl pot in the depth of subframe and load deck as the heel board is taller so might be possible?. |
971 Posts Member #: 3228 Post Whore North of the Netherlands |
14th Dec, 2016 at 12:11:22pm
I have a Van that I want to inject.
Edited by Yo-Han on 14th Dec, 2016. Dazed and Confused.... |
14th Dec, 2016 at 08:33:46pm
Can you get one with a built in pre pump? |
15th Dec, 2016 at 08:53:52am
I was thinking about fitting and 'ordinairy' facet liftpump on the subframe, using the original tank supply.
15th Dec, 2016 at 10:31:41am
Click the thread link at the top that's where I've got to so far. Haven't worked out it in 2 years. |
15th Dec, 2016 at 01:42:05pm
I fitted an external swirl pot. Pumped fuel into that and then returned to the filler neck.
15th Dec, 2016 at 04:05:51pm
Ah right that looks alright thanks for that. So no mods were needed to the tank? |
15th Dec, 2016 at 04:18:16pm
Did you buy that swirl pot from somewhere or had it fabricated? |
6549 Posts Member #: 1149 #1 Basshunter Fan Force Racing ICT Dept Manager Miglia Turbo Am frum Yokshyer tha noes! |
15th Dec, 2016 at 06:24:20pm
Ive bought a swirl pot with integrated fuel pump off ebay. It was about 130 for China iirc.
16th Dec, 2016 at 07:35:56pm
niceone! cheers for your help guys! |
Page: |
