Page: |
Home > General Chat > K1100 auto subframe. | |||||||
15 Posts Member #: 10647 Member |
5th Dec, 2016 at 10:30:26pm
hi there
6th Dec, 2016 at 12:19:27am
it's pretty easy to modify your own frame. Basically cut out where the mounts go, and plate on the outside of the holes. This drops the engine by a shade under 1/2". If you want 1/2", simply space out the plates by 0.5mm each side before welding into place... Edited by TurboDave16V on 6th Dec, 2016. On 17th Nov, 2014 Tom Fenton said:
6th Dec, 2016 at 08:49:12pm
I am fairly certain sprocket did this to his build? Maybe worth looking through his build thread. I think it is just a case of redrilling the mounting holes on the auto subframe lower down as the frame itself is slightly wider at the engine mounting point, so the rubber mounts sit lower in the taper of the frame. I was going to do this to mine, but after drilling a million holes in my manual subframe I decided I couldn't face doing it again. :) if you need a frame I have a good solid frame here, that I no longer need. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
![]() 539 Posts Member #: 6807 Post Whore York |
6th Dec, 2016 at 09:20:52pm
I've used an auto subframe. The side spars of the frame are too wide to just drop the engine through the frame and redrill the holes, it would sit too low. So a couple of 2mm thick spacers were used on mine which dropped the engine about 15mm. Then the holes were drilled in the new location.
Edited by adcyork on 6th Dec, 2016. |
45 Posts Member #: 11153 Member |
6th Dec, 2016 at 10:28:20pm
This is a good modification, but be careful if you run your car very low. The reason for this is if you just lower your car your ncrease the angle of the drive shafts in the cv pot joints. Lowering the engine will further increase this angle.
6th Dec, 2016 at 11:05:38pm
I thats where my auto subframe from home ended up think my old man sold it to you with the front bulkhead down in surrey?
On 6th Dec, 2016 matty said:
I am fairly certain sprocket did this to his build? Maybe worth looking through his build thread. I think it is just a case of redrilling the mounting holes on the auto subframe lower down as the frame itself is slightly wider at the engine mounting point, so the rubber mounts sit lower in the taper of the frame. I was going to do this to mine, but after drilling a million holes in my manual subframe I decided I couldn't face doing it again. :) if you need a frame I have a good solid frame here, that I no longer need. |
6th Dec, 2016 at 11:06:01pm
thanks for the info guys! |
6th Dec, 2016 at 11:06:04pm
![]() 489 Posts Member #: 9159 Senior Member Devon |
7th Dec, 2016 at 08:07:03am
There is someone selling an already modified auto subframe on tmf, should save you some work? |
7th Dec, 2016 at 05:25:21pm
On 6th Dec, 2016 pickupmad87 said:
I thats where my auto subframe from home ended up think my old man sold it to you with the front bulkhead down in surrey? On 6th Dec, 2016 matty said: I am fairly certain sprocket did this to his build? Maybe worth looking through his build thread. I think it is just a case of redrilling the mounting holes on the auto subframe lower down as the frame itself is slightly wider at the engine mounting point, so the rubber mounts sit lower in the taper of the frame. I was going to do this to mine, but after drilling a million holes in my manual subframe I decided I couldn't face doing it again. :) if you need a frame I have a good solid frame here, that I no longer need. Haha yes he did! I needed a manual subframe and I didn't realise that was an auto one at the time. I kept hold of it to use on mine, but I will never get round to it. Your welcome to buy it back, it has been dry stored since. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
7th Dec, 2016 at 06:55:03pm
ah okay mate. you down this way at all soon?
7th Dec, 2016 at 08:53:40pm
I don't have any trips planned your way at the moment. My workshop is only about 10mins from junction 7 off the M40 though, so not too far from you. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
7th Dec, 2016 at 09:12:15pm
can you pm me your mobile number and ill give u a ring tomoz and sort something out? |
7th Dec, 2016 at 09:12:18pm
8th Dec, 2016 at 08:40:31am
Will do.
![]() 84 Posts Member #: 10547 Advanced Member Northern Ireland |
10th Dec, 2016 at 04:13:22pm
When you cut the inner plate from around the subframe mounting holes and add plating to the outside, do you then need to re-drill the holes in a lower position?
Instagram: bighill93
10th Dec, 2016 at 05:48:06pm
Yes. I made a jig that sits on a 1/2" spacer on top of the subframe.
Edited by TurboDave16V on 10th Dec, 2016. On 17th Nov, 2014 Tom Fenton said:
10th Dec, 2016 at 05:55:33pm
Would you happen to have a pic of that Dave?
Page: |
