Page: |
Home > General Chat > Newbie looking for advice | |||||||
4 Posts Member #: 11476 Junior Member |
29th Nov, 2016 at 09:16:49pm
Hello all had my mini for around 4 years now just fully rebuilt a 1275 to a 1312 but now it's all together in debating to turbo or not??
264 Posts Member #: 11029 Senior Member Crewe |
29th Nov, 2016 at 09:34:01pm
hello and welcome ,the search button next to log out will be a great place to start reading and will give you all the answers you will need.
Edited by monsterob on 29th Nov, 2016. Outside the box |
![]() 4629 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
29th Nov, 2016 at 09:37:01pm
The Turbo head is basically no different to any other 940 casting. The difference lies in the sodium filled exhaust valves. Most people just bin these anyway and run the stainless race valves which are superior.
29th Nov, 2016 at 09:45:16pm
Can you provide a detailed list of what I will need? Or what I could use off my engine as it stands it hasn't even been run yet so everything's new
29th Nov, 2016 at 09:58:24pm
Welcome to TM
3 Posts Member #: 11339 Junior Member NSW, Australia |
30th Nov, 2016 at 02:23:35am
You can find the archive here of the turbo-mini website with lots of useful info to read.
Edited by timmy201 on 30th Nov, 2016. |
30th Nov, 2016 at 07:41:28pm
Why did they run sodium filled exhaust valves?
On 29th Nov, 2016 Turbo Phil said:
The Turbo head is basically no different to any other 940 casting. The difference lies in the sodium filled exhaust valves. Most people just bin these anyway and run the stainless race valves which are superior. The turbo head runs 33mm inlet valves as standard, in which case your 35.6mm inlets won't fit unless you have the head modified to suit. Phil. |
30th Nov, 2016 at 08:05:07pm
to cool the exhaust valve, i gues the sodium must be very thermaly conductive. On 28th Aug, 2011 Kean said:
1st Dec, 2016 at 12:04:21am
The valve is a hollow stem filled with sodium, which melts at around 100c. On 26th Oct, 2004 TurboDave16v said:
1st Dec, 2016 at 06:22:53am
http://www.turbominis.co.uk/forums/index.php?p=search
On 29th Nov, 2016 Minimotion said:
Can you provide a detailed list of what I will need? This whole forum is a detailed list of what you will need ...... and you know the best bit? .. its absolutely free...... take as much information as you want Yes i moved to the darkside |
Page: |
