Page: |
Home > General Chat > Fitting spi tank to my 998 | |||||||
81 Posts Member #: 11403 Advanced Member |
16th Nov, 2016 at 02:01:39pm
How do I plump the spi tank into my 998? There's 2 pipes on the pump, and a pipe on the top of the tank going into a round thing with another pipe coming off that, where do thy all go? I know one on the pump will goto the carb but which is which and is the pipe going into the top for fuel return or is this a vent pipe?
Edited by steve2016 on 16th Nov, 2016. |
108 Posts Member #: 9182 Advanced Member |
17th Nov, 2016 at 09:59:14pm
The two pipes on the pump are a feed and return which go to a fuel regulator which in turn feeds the carb. The third pipe is a vent which should be feed to the outside of the car. I would think 8mm pipes would be fine for a 998. The power is just positive and negitive although for safty reasons it is best feed through an inertia switch or relay operated by oil pressure in case of an accident where you don't want high pressure fuel spraying everywhere. |
![]() 552 Posts Member #: 300 Post Whore Cumbria |
18th Nov, 2016 at 02:05:12pm
http://s45.photobucket.com/user/kambocars/...wiring.jpg.html Here for the craic..
18th Nov, 2016 at 10:10:16pm
On 17th Nov, 2016 viz139 said:
The two pipes on the pump are a feed and return which go to a fuel regulator which in turn feeds the carb. The third pipe is a vent which should be feed to the outside of the car. I would think 8mm pipes would be fine for a 998. The power is just positive and negitive although for safty reasons it is best feed through an inertia switch or relay operated by oil pressure in case of an accident where you don't want high pressure fuel spraying everywhere. 8mm is fine for 998 yeah ![]() Yes i moved to the darkside |
22nd Nov, 2016 at 07:59:29am
Thanks what regulator do I need? I have a regulator now but it doesn't have fuel return
![]() 2094 Posts Member #: 9894 Post Whore Dorking |
22nd Nov, 2016 at 10:45:00am
You want the standard metro turbo fuel pressure reg. This has a return on it.
22nd Nov, 2016 at 11:24:36am
Thanks, could I still run the metro turbo regulator on my non turbo 998 until I finish the project?
22nd Nov, 2016 at 02:04:25pm
I currently have this regulator
![]() 5988 Posts Member #: 2024 Formally Retired Rural Suffolk |
22nd Nov, 2016 at 02:29:08pm
You would probably damage the SPI pump as it is designed to flow through a regulator with a return which allows a constant flow whilst varying the pressure. Running the pump against that regulator doesn't allow a constant flow which the injection pumps are designed for.
24th Nov, 2016 at 02:10:26pm
Thanks so I just need the metro regulator and and flow gauge thing to set the regulator pressure up and leave the pressure sensor line off and I should be good to go
Page: |
