Home > General Chat > Advice 10" x 6" or 7" for use on the road
Nathan1293
Member #: 11153
Hi everyone
I have been very lucky and recently purchased a set of 10" x 6" spectrum split rims. I've always liked them, ever since seeing them on Miglia's in the early 90s. Never thought I'd ever own a set! *smiley*
Anyway they are currently 10" x 6" but the outer rims are a bit damaged. So as I am replacing them I thought maybe this is a good time to go wider!
I intend to se either Yokohama A008 or A032R tyres.
I'm not super keen on the stretched look for its own sake, but if there is a performance advantage then I'm interested. Maybe 10" x 6.5" is a happy middle ground.
The tyres on the 10 x 6" rims look as though a wider rim would be fine, just maybe not 7" wide?
I've run 10" x 6" revolutions with A008s and loved that setup.
The planned engine is for some serious hp! *happy*
If anyone has experience of both setups can you share your experiences?
Nathan
D4VE
Member #: 10749
lowestoft suffolk
Gone from 7's to 6's with low et to hopefully lower torque steer! Not ever noticed N/A but turbos sudden surge makes it a different animal..
Even on 6's ive had grief off some people as yokohama states on their site that 5.5 is the recomended size.. i know people run diff sizes but 'yoko say'
Nothing gets past Dave lol
jonny f
Member #: 9894
Dorking
Zero advantage.
Stay with 10x6.
Also, what's up with the barrels? Most curb rash etc can be removed pretty easily with a file and some wet and dry.
Edited by jonny f on 15th Nov, 2016.
I run 5.5 and I'm happy, but I also run a low power output for this site
Nathan1293
Member #: 11153
The rims have some chucks taken out of them, but there are also a few flats on them. I assume from tyre fitters. A file wouldn't fix them. It would need welding or machining. In fact one or two outer rims are far worse than the others, but it seems a new rim would be a different pattern so not match the others.
I'm running 7x10 conversions. I'd probably drop them down to 6 or 6.5s if i was replacing them now
Been running 7.5s for ages but never had a car on the road long enough to know *Rofl!*
jonny f
Member #: 9894
Dorking
Ok fair enough!
Carl (force racing) can make up spectrum barrels. He did a pair of inners for me a while ago.
