Page: |
Home > General Chat > oil pump | |||||||
3074 Posts Member #: 1348 Post Whore wakefield West Yorks |
14th Nov, 2016 at 07:51:05pm
Evening all, whats the up to date oil pump to use !
6729 Posts Member #: 618 Post Whore Glasgow |
14th Nov, 2016 at 08:10:21pm
I think the minispares one has now be re-engineeredso should be ok |
81 Posts Member #: 11403 Advanced Member |
15th Nov, 2016 at 08:44:29am
What oil pump should be used on a 998 turbo? Just the stock 998 one or does it need uprated? |
10021 Posts Member #: 1456 Mongo Barnsley, South Flatcapshire |
15th Nov, 2016 at 09:06:04am
Way I see it Rick is that when you are spending all that money on an engine why scrimp on the oil pump? For me I'd use the swifty pump. If something is worth doing, it's worth doing half of. |
15th Nov, 2016 at 10:21:20am
Neither helps me lol .
15th Nov, 2016 at 12:01:11pm
Not broken don't fix it is probably the right way to do it. I thought you WERE in need of a new pump. If something is worth doing, it's worth doing half of. |
15th Nov, 2016 at 12:07:06pm
do have a quick evaluation of the port to cam bearing distance though.... On 28th Aug, 2011 Kean said:
Site Admin 15300 Posts Member #: 337 Fearless Tom Fenton, Avon Park 2007 & 2008 class D winner & TM legend. |
15th Nov, 2016 at 12:18:41pm
It hasn't given you any issue Rick. I'd just have a quick look to ensure there is no scoring on the rotors then put it back where it came from.
2094 Posts Member #: 9894 Post Whore Dorking |
15th Nov, 2016 at 05:51:28pm
I went with swiftune but I also had a new minispares turbo type. Which they exchange for my old turbo one.
6965 Posts Member #: 507 Fastest A Series Mini in the World leeds/wakefield. |
16th Nov, 2016 at 08:22:26pm
I have only ever fitted the bog standard pump. when they were AE then standard Minispares item.
9812 Posts Member #: 332 Resident Cylinder Head Modifier Mitsi Evo 7, 911, Cossie. & all the chavs ...... won no problem |
16th Nov, 2016 at 08:29:02pm
yes the std pump is up to the job
16th Nov, 2016 at 10:36:57pm
Thanks men , toms has had a quick look and were keeping the one thats in in !
Page: |
