| Home > A-Series EFI / Injection > Using normal EFI on MPI A-series | |||||||
520 Posts Member #: 2093 Post Whore Grenoble, France |
13th Nov, 2016 at 12:39:27pm
Edited by alpa on 13th Nov, 2016. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
13th Nov, 2016 at 02:11:47pm
This isn't a direct answer (because I don't know what everyone uses, most use some form of wet manifold / throttle body / electronic carb rather than true port injection) but what may be of interest is if you look at the Rover MEMS (factory MPI) it is their standard four injector system but with the four outputs paralleled up to drive just two injectors in the specified sequence of four (two shots each).
13th Nov, 2016 at 06:13:00pm
A number of us use the MS3 with the MS3X expansion. The firmware does not have any specific siamese port features, so we can either use 2 out of the 4 injector outputs or use all 4 doubled up on to the 2 injectors.
13th Nov, 2016 at 11:42:58pm
I see Rod. It must be tricky to adjust beginning and duration of this combined pulse right ? It must be changing depending on RPM and intake pressure.
14th Nov, 2016 at 09:30:08am
On 13th Nov, 2016 alpa said:
I see Rod. It must be tricky to adjust beginning and duration of this combined pulse right ? It must be changing depending on RPM and intake pressure. I did not know exactly what Jean made in MS2. Alpa, I've never used that feature in anger. It came into being when, during early testing of the siamese code on a JimStim and with the MS2 hooked up to a scope, we found that if the two consequitive pulses (on each injector) became too large (ie, too wide) and started to overlap, it wasn't a clean process - sometimes one would get skipped instead of the two merging into one double width one. After much discussion with Jean, there was no easy fix so we decided the best solution was to provide the option of creating a double width pulse (if it was likely to be required) at a chosen RPM (as the pulses get wider as RPM rises so the likelyhood of needing to use the feature became RPM based). If you set the RPM above the rev limit (as I do) it willl never happen, if you set it very low it will be in that mode continuously and set it somewhere inbetween and it will switch modes. We later found out that that is what Rover did for the MPI but obviously with a fixed setting. If the injectors are big enough for chosen power so that the pulses never get wide enough to approach each other it isn't required. And as Paul has said, if we don't want large injectors we use additional injectors and staging. Even the humble MS2, with a small but often used modification, is capable of four chanels so Jean wrote the code to allow chanels 3 and 4 to be the second stage in siamese. The MS3 has 8 chanels anyway. In the MS2 merged pulse mode, the actual adjustment of "beginning and duration" (after choosing your activation RPM) is quite straightforward. You have the choise of injection timing being set by start of pulse, mid pulse or end of pulse - that's in the code anyway whether this mode is used or not - then the choise of a fixed value BTDC throughout the MAP/RPM range or the usuall table of MAP (load) up the y axis and RPM along the x axis and your chosen timing values in the cells. Schrödinger's cat - so which one am I ??? |
14th Nov, 2016 at 04:02:15pm
Thanks
14th Nov, 2016 at 06:40:14pm
Well the whole idea is to inject during open valves - or actually enough before to allow for the transit time - but to make sure the fuel goes in through the right open valve.
14th Nov, 2016 at 11:53:39pm
Thanks. Your explanations are clear.
Edited by alpa on 14th Nov, 2016. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
15th Nov, 2016 at 07:56:22am
Co-incidentally I recently read the description on your website of how you approached the issue. I was a bit surprised at first about injecting on a closed valve but, as the inner opens first, so long as all that fuel has gone before the outer valve opens and you get the timing spot on for the outer valve, and the amount right, it obviously works.
15th Nov, 2016 at 09:41:41am
I'm quite sure of my analysis about why in-outer are disbalanced. So injecting on the closed valve even helps.
Edited by alpa on 15th Nov, 2016. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
