Page: |
Home > A-Series EFI / Injection > 630cc injectors | |||||||
208 Posts Member #: 438 Senior Member London |
10th Nov, 2016 at 03:14:18pm
I have seen these Hi-z injectors on ebay. Thinking they will be about right for staged sequential injection on my engine (aiming for 130-150bhp max).
10th Nov, 2016 at 04:16:15pm
Assuming that your are going to use port injection, then they would be around the right capacity.
608 Posts Member #: 1106 Post Whore Hungerford, Berks |
10th Nov, 2016 at 08:23:24pm
Perhaps a simpler route to start with would be to use 2off Siemens Deka IV 875cc/min (FI14992).
’77 Clubman build thread
11th Nov, 2016 at 08:07:19am
Again, making the assumption you are going to be using siamese port injection, I agree with Paul that the total capacity (staged) is OK, probably a bit more than OK, but as Graham says, and particularly for your proposed BHP, a simple non-staged setup with just a pair of larger injectors might be better.
Edited by Rod S on 11th Nov, 2016. Schrödinger's cat - so which one am I ??? |
11th Nov, 2016 at 01:37:42pm
Okay. So that's a surprise, I thought even at the lower power figure I would need 1000cc capacity or more. If I can get away with a pair of injectors that makes life easier, and also reduces cost. |
11th Nov, 2016 at 02:04:19pm
There are many "calculators" out there on the web but they all assume standard batch or sequential injection on an 8/16 whatever port engine so are based around an 80-85% duty cycle.
520 Posts Member #: 2093 Post Whore Grenoble, France |
11th Nov, 2016 at 05:57:02pm
Mine are Siemens Deka 65lbs, 1 per injection port, so two in all. Enough for 100hp not much more. Excellent injectors ! I tried 2 other types before these ones and the difference in partial loads was huge, very smooth ride now.
Edited by alpa on 11th Nov, 2016. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
3588 Posts Member #: 655 Post Whore Northern Ireland |
12th Nov, 2016 at 01:00:22pm
Injectors are kind of important. Buy a reputable brand every time....not un-named ebay shite. 9.85 @ 145mph
Page: |
