Home > Technical Chat > Megajolt question
TurboDave
Member #: 11135
(Not "TurboDave" - He is TurboDave16v)
Halstead, Essex
im going to run mega jolt on my turbo motor. I have drilled into the inlet and put a fitting in for the MAP type Ecu. I'm now adding in a boost gauge and plumbing up the recirc valve and need to have more fittings in the manifold. Do they all need to be separate or can they be fitting in line with a t-piece?
JT
Member #: 637
Hertfordshire
I've got mine separate as the manifold I have alowed me to.
I'm sure a few people tee them from one though.
My build thread..
Ideally I'd keep them separate if possible.
Phil.
metroturbo
Member #: 989
North Yorkshire
At the very least I'd put the gauge and the megajolt on the same connection. That way, what you see on the gauge is what the megajolt sees, and if the sensing pipe pops off you'll hopefully notice it before anything goes wrong.
