Page: |
Home > A-Series EFI / Injection > Ignition map - opinions? | |||||||
![]() 52 Posts Member #: 11169 AKA: Smegmium Derby, ish |
27th Oct, 2016 at 08:38:54am
Morning all
"If its not broke, whack a turbo on it"
![]() 5988 Posts Member #: 2024 Formally Retired Rural Suffolk |
27th Oct, 2016 at 09:00:55am
It looks very similar to my base table generated by TunerStudio for an MS2 with a similar load (MAP) range and I've had no problems with mine.
27th Oct, 2016 at 11:23:03am
Thanks Rod - and..
27th Oct, 2016 at 11:49:41am
On 27th Oct, 2016 Smegmium said:
However im not getting an engine rpm showing in tuner studio.... Any ideas?! That has to be something wrong with how you have setup the gauges etc in TunerStudio. If it runs, it means the microsquirt is 100% definately getting the crank signal. The engine wouldn't run without the ECU being synched to the crank RPM signal. What are the green/red boxes at the bottom of TS showing ? Schrödinger's cat - so which one am I ??? |
28th Oct, 2016 at 12:29:54pm
I thought the EDIS module sends a spark based on the toothed wheel, the MS just modifies that with PIP & SAW..?
28th Oct, 2016 at 12:38:27pm
rod is assuming (like I did) that you are running coilds direct from the Microsquirt.
28th Oct, 2016 at 01:22:45pm
Yep, like Joe says, I was assuming you were running the coils direct.
2nd Nov, 2016 at 01:46:41pm
Arg, figured out what was going on, ish...
2nd Nov, 2016 at 03:22:43pm
I meant to say to reflash the firmware, sorry t slipped my mind!
Page: |
