Page: |
Home > General Chat > Drills | |||||||
603 Posts Member #: 1938 Post Whore near Dundee |
9th Oct, 2016 at 08:01:28pm
so i need to get a drill set, a quick trip to machine mart revealed that we are quite a bit out of touch. titanium,hss and diamond.
9th Oct, 2016 at 08:09:25pm
hand drill? hand drill will eventually kill any drill bit cheap or not, imo
Edited by Brett on 9th Oct, 2016. Yes i moved to the darkside |
![]() 882 Posts Member #: 9774 Post Whore Buckinghamshire |
9th Oct, 2016 at 08:13:35pm
Possibly a useful vid:
http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
9th Oct, 2016 at 08:31:18pm
For general use, i got this set a few years back which is still going strong. They do have their limitations and i do use some cobalt bits for the pillar drill when i've detailed work to do
Edited by Rob Gavin on 9th Oct, 2016. |
10th Oct, 2016 at 08:08:35am
To be totally honest, learn how to sharpen bits properly, and it doesn't really matter what you buy for general car use, e.g. drilling holes, making brackets for things, drilling out sheared bolts etc.
Edited by Tom Fenton on 10th Oct, 2016.
10th Oct, 2016 at 11:33:33am
Olistation 😀😀 Yes i moved to the darkside |
10th Oct, 2016 at 01:24:02pm
Yep. You need a set of bog standard but quality 'black' jobber drill bits. None of these fancy coatings and stuff.
![]() 696 Posts Member #: 10034 Post Whore Birmingham |
10th Oct, 2016 at 01:36:50pm
As above, lubrication, sharpening and low RPM to get the most out of whatever you choose.
10th Oct, 2016 at 04:42:07pm
Only using low rpm is not correct. Use low rpm on a small bit and you will be disappointed with the results. There are charts all over the net to give an indication of the required speed for different size bits and different materials. In general, as the drill bit gets bigger, the speed lowers. You might need 1200rpm to put a 5mm bit through mild steel, but change to a 13mm bit and the speed needs to be more like 400rpm. |
10th Oct, 2016 at 09:50:38pm
I think what he was getting at was battery drill only have two speeds, too fast and too slow |
11th Oct, 2016 at 05:38:22pm
thanks for the replies,
11th Oct, 2016 at 08:40:37pm
Can't go wrong with Dormer drills, out of any they are what I would choose. Ive had a set of Dormer drills for years and pretty much always get used drilling out laser cut holes in stainless which can be bloody hard! HSS are good for most things, carbon steel drills in my experience are pretty useless, apart from on aluminium. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
Page: |
