Home > Technical Chat > ARP rod bolts
phillips934079
Member #: 10703
newcastle
Recently stripped my engine and it has a set of ARP bolts in it I was wondering if the torque setting is different from standard if so what is it.
Thanks phill
Or some precision brutality
Smackfiend
Member #: 9867
If it's a 1275 like mine it's 35 ft lbs using lube:
http://arpinstructions.com/instructions/206-6002.pdf
phillips934079
Member #: 10703
newcastle
Thanks that's exactly what I needed to no
Thats using arp lube though not just oil
*wink*
