Home > Wanted > Wanted - Specialist Components Monoblock 4 pots
Evoderby
Member #: 9987
Amsterdam
As title says....looking for a pair of SC monoblock calipers, preferably unused.
D4VE
Member #: 10749
lowestoft suffolk
Sc not sell them anymore?
Nothing gets past Dave lol
Evoderby
Member #: 9987
Amsterdam
Next batch planned for production early next year....
from what ive heard the first batch was the only batch,
i heard the production costs ended up being quite high and they discontinued rather than passing on the high costs
D4VE
Member #: 10749
lowestoft suffolk
My mates just got a job there so i shall ask him...
Disappointed I never got to use mine.
viz139
Member #: 9182
A friend of mine had a problem with these, the link pipe hits the tie rod when the suspension is fully down on the bump stop.
Evoderby
Member #: 9987
Amsterdam
Wow thanks for the heads up, that could potentially lead to dramatic if not lethal failure.
Do you know whether your friend runs dry or hydro suspension? This is what minispares state on their calipers: IF FITTING TO HYDRO CARS BEWARE OF CLEARANCE PROBLEMS IF ADJ TIE BARS AND NEG CAMBER ARMS ARE FITTED ALTHOUGH NOT ADVISED
Did your friend/SC manage to solve the situation? Again thanks for the heads up!
this rings a bell, I think it may be with the ones witht he dat square end as below,
Somthing like the Kad ones should be ok
Edited by Joe C on 19th Aug, 2016.
or maybe clearence them with a grinder
I thought it was a problem on nearly all 4 pot calipers, they foul full droop full lock.
ministef1
Member #: 1791
Cranleigh, surrey
I thought thats why KAD makes a steering lock plastic thing, for the rack? thats what I had to use on my KAD 6 pots
"Cars are a lifetime of pain"
alaskanow0
Member #: 8466
Mansfield
I sold my Monoblocks because just like the KAD 4 ports they hit the Allspeed Tie bars.
However I have another pair fitted to my lightweight project without any issue, using Force Racing Ti bars.
Evoderby
Member #: 9987
Amsterdam
Very insightful!
I run minisport Grp A adjustable tie rods, did have a look at the KAD ones but decided against them at the time because of limited thread engagement.
The minisport items are rounded where they fit the bottom arm so probably better clearance wise than the square types available.
That being said, a caliper body with internal fluid routing getting in contact with the tie bar is a nuisance....an external link pipe on a monoblock getting bumped/split however is far more serious.
I'm sure it can be dealt with as Alaskanow0 has stated, simply unpacking your new toys...fitting them in record time and going for a test drive seems unwise in this instance.
Good to have this on record here....once again what a great place this forum is! *smiley*
Rammie2000
Member #: 10190
belgium
I had the round ones but still rubbed on full lock. Made a ( cant remember how named in England hard white "plastic" thats used on machines) ertalon bushes for steering rack
Evoderby
Member #: 9987
Amsterdam
Which calipers are you running?
I've got Wilwood calipers on 10.25" Discs and the caliper hit the tie bars on full lock. Fitted the KAD limiters and now they don't hit anything. The limiters are good for two reasons, firstly, as above, they help prevent the calipers fouling suspension components, secondly, they reduce the torque angle on the CV joints.
Rammie2000
Member #: 10190
belgium
Im running the 4 pots 50 years minisport or so something been long long time ago i fitted them
viz139
Member #: 9182
Sorry for long delay in reply.
My friends car is dry suspension and he is running the square end adjustable tie rods.
D4VE
Member #: 10749
lowestoft suffolk
Heard the same from sc
