Page: |
Home > Show Us Yours! > jnr's Mk1 | |||||||
3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
28th Jul, 2016 at 07:20:58am
Well, Nathan's Mk1 has arrived and it's fair to say there is quite a bit of work ahead of us.
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
28th Jul, 2016 at 07:25:36am
28th Jul, 2016 at 07:46:12am
Yep, all the arms etc will swap into the early subframe.
28th Jul, 2016 at 08:10:34am
Cheers buddy, it's a 1966 Morris
28th Jul, 2016 at 08:16:17am
Going to re fit the subbies and brace the shell for sure ! I will ultimately be soda blasting the shell and having it coated professionally before paint goes back on
28th Jul, 2016 at 09:16:39am
great stuff, being a 66 you shouldnt run into too much trouble getting pannels like on earlier shells, ( like the flat sills on the 59/60's)
29th Jul, 2016 at 07:01:11am
Well We had an afternoon in the garage yesterday, went to fit the front subframe and immediately found it didn't fit. It appears who ever fitted the front N/S wing and front panel had done so without the subby in place...
29th Jul, 2016 at 08:10:24am
On 29th Jul, 2016 Richie said:
Purchased some tungstens for it yesterday only to be told from a local welder that I should bin them as they are the toxic ones 😣 (I bought thoriated tungstens) which I managed to blow to bits very quickly indeed in any event I use them for mild steel and stainless with no concerns and they were specified for stainless coded welds where I used to work. I presume he's referring to the fact that the 2% throrium they are doped with is mildly radioactive. It's harmless while welding but just wear a simple dust mask when grinding them, it's only if you breathe in the dust from grinding that there is a tiny, tiny risk as the thorium is an alpha emmiter so you don't really want it in your lungs. I presume he said ceriated instead (for mild steel)? Personally I don't like them and just use common sense with the thoriated ones. Schrödinger's cat - so which one am I ??? |
29th Jul, 2016 at 08:35:06am
Cheers Rod.
31st Jul, 2016 at 10:25:51am
Well, still assessing the job at hand, and noticed that the nearside has been repaired to the same low standard... Can anyone tell me if this is correct mk1 outer sill ? It has 6 raised sections.
450 Posts Member #: 10396 Advanced Member Formerly mk2turbo Stoke-on-Trent |
31st Jul, 2016 at 10:39:42am
Think that's the later outer sill, mk1 should have 4 raised sections |
31st Jul, 2016 at 11:03:12am
FFS why am I not surprised :)
31st Jul, 2016 at 04:22:43pm
Better than nasty over sills |
31st Jul, 2016 at 05:08:57pm
true... shit soaked paper mache would be better than over sills
3rd Aug, 2016 at 10:22:17am
I've gone for the replace panel rather than patch now after I started stripping the paint back looks like a patch work quilt. Passenger side had 4 sets of sills on oringal + 3 over sills. So gotta do full floor door steps and that to fix it. I feel your pain haha but still tidy 66 |
4th Aug, 2016 at 07:38:12pm
cheers.
Edited by Richie on 5th Aug, 2016.
Page: |
