Home > Wanted > long shot...wanted: rear radius arm reamer
pieter
Member #: 7577
belgium
can anyone help me with a rear radius arm reamer for classic mini/metro
as i get it right this is a sykes pickavant tool.
I have a lathe and some radius arms that are in need for repair...
So if you have one sitting on the shelf, help a brother out.
Thanks in advance!
pieter
Member #: 7577
belgium
Bump
Rammie2000
Member #: 10190
belgium
doe i; hier met een as waar slots in getrokken zijn werkt perfect
Get an old pin, machine a taper on one end and some angled slots in to cut away at the soft bushings
pieter
Member #: 7577
belgium
Any pics would be helpful guys thanks for the top tip
Rammie2000
Member #: 10190
belgium
ga em es zoeken
Found this on google, gives you some idea of what to do, im not near mine to photograph, but you can weld an old socket onto the other end to turn the reamer into the bush
pieter
Member #: 7577
belgium
nice, good stuff
