Home > For Sale > bits and bobs clearing/leaving breaking so may have parts u need to
kezzboycat
Member #: 10371
leicestershire
crank 6232 needs a regrind
£50
1275 block standard bore with mains will horn otherwise rebore accordingly
the bottom ive started to grind flat began to fit oil jets no holes drilled or etc so wont effect it anyway
£120 SOLD
water pump bypass plate
£10
remote oil filter housing braided lines
£50
megajolt unit
brand new ecu with soured coilpack plug/sensors
200 SOLD
u will need triggerwheel bracket
ive got a brand new loom somwhere but that will be additional if i can find it
SOLD
vernier med adjustable tiiming chain
nearly new
£85
bmw oil jets brand new never used
£50
shall add more stuff shortly
forged bits and etc
Edited by kezzboycat on 10th Jul, 2016.
Tuctuc
Member #: 10894
Lancashire
I'll take the megajolt assuming its MAP - Pm'd
sim_ou_nao
Member #: 114
Porto/Portugal
The crank is STD size?
Pedro Silva
Intrested in the block. Do you have some pics
kezzboycat
Member #: 10371
leicestershire
yes
kezzboycat
Member #: 10371
leicestershire
forged je pistons plus 60 15cc dish
500
forceracing fully worked crank
600
kezzboycat
Member #: 10371
leicestershire
front rad/ oil cooler 35 for the pair
sim_ou_nao
Member #: 114
Porto/Portugal
What is the cost to send to Portugal?
On 4th Jul, 2016 kezzboycat said:
yes
Pedro Silva
kezzboycat
Member #: 10371
leicestershire
25 pound to send to Portugal
yes
kezzboycat
Member #: 10371
leicestershire
turbo carb
£120
kezzboycat
Member #: 10371
leicestershire
Shall be adding new stuff to this shortly
kezzboycat
Member #: 10371
leicestershire
CARB SOLD
forged je pistons 15cc plus 60 1330
500 ono
