Page: |
Home > Non-Mini Discussion > LARGE pressure spike problems | |||||||
3rd Jul, 2016 at 04:56:56pm
This is a problem on the hillclimb single seater (Z750cc Kawasaki motor with a turbo).
2909 Posts Member #: 83 Post Whore Glasgow, Scotland |
3rd Jul, 2016 at 05:02:13pm
Try a different flat shift strategy you may be causing a burn with inlet valves open. I use a straight up ignition cut. No retard or fuel cut atall. turbo 16v k-series 11.9@118.9 :)
3rd Jul, 2016 at 05:04:44pm
I tried ignition cut. It sounded like a shot gun going off everytime I changed gear. I got my collar felt by the noise police after my first run.
3rd Jul, 2016 at 05:13:31pm
Deffo try less fuel cut, I'm thinking if it's too lean the burn will slow down so it's still alight when the intake opens,
3rd Jul, 2016 at 05:58:21pm
It is running wasted spark, but has 4 coils.
3588 Posts Member #: 655 Post Whore Northern Ireland |
3rd Jul, 2016 at 08:28:33pm
Try more fuel cut !! on the cars I cut 100% fuel for the duration of the shift. That also sounds like a huge amount of retard ?
Edited by stevieturbo on 3rd Jul, 2016. 9.85 @ 145mph
3rd Jul, 2016 at 08:37:38pm
I had no reference to start from and someone said 50deg. From a gear change point of view the settings work.
3rd Jul, 2016 at 10:25:34pm
50deg, whilst not fully killing the engine sounds like a recipe for problems.
3rd Jul, 2016 at 10:56:50pm
Wasted spark is your issue. Think of where the (no longer) wasted spark is happening. With that much retard, it is happening in the middle of the intake stroke. |
4th Jul, 2016 at 07:50:42am
Just trying to work this out. 30deg BTDC with 50deg retard is 20deg ATDC on cylider 1.
6745 Posts Member #: 828 Post Whore uranus |
4th Jul, 2016 at 08:22:49am
cyl4 ?
4th Jul, 2016 at 08:56:37am
Is this what was hampering you at Barbon?
4th Jul, 2016 at 09:44:39am
On 4th Jul, 2016 robert said:
cyl4 ? Fastest 998 mini in the world? 13.05 1/4 mile 106mph
4th Jul, 2016 at 09:44:46am
Barbon was an issue with the regualtor.
On 4th Jul, 2016 graemec said:
Is this what was hampering you at Barbon? Did you get out again at Harewood? Edited by wil_h on 4th Jul, 2016. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
Page: |
