Home > For Sale > K1100 turbo manifold
Hi, due to a recent upgrade, I am selling my K1100 turbo manifold. Will fit a GT17 and many other T2 stud patterned turbos. It will require a bulkhead box to be fitted. Made from 316 stainless. £250 + postage.
Thanks
Matt
Edited by matty on 21st Jun, 2016.
Provisionally sold.
I've got to do it the hard way, gt20 and no bulkhead box!
Haha I'm not sure if that is even possible unless the turbo goes at the top?
It does fit down the back, and with a fettle on the block and a touch on the compressor housing should give about 8mm clearance with a standard engine steady.
put the turbo up top, theres room to get decent pipework down the back, although you'll have to sweep the down pipe round past the master cyls....
I was going to get Matty to do me a mnifold but started sizing stuff up and got carried away...
[imghttp://i95.photobucket.com/albums/l154/mini13_2006/Mobile%20Uploads/DSC_0012_2_zpsdccfoscp.jpg][/img]
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
o yess.... i like that set up joe !!
nothing a double layer air gap head shield cant fix
lol, theres actually a fair bit of room, a load more than if a turbo was stuffed down there, I was toying with the idea of getting it coated too though.
make sure you have adequate clearance on the actuator, my engine was rubber mounted but unable to move due to the solid steadys
i squished and bent them, damaging the actuator, engine saved by an overboost spark cut
good point from Bret there, also ziptie/clamp any hoses on, I see lots that are just left pushed on, and have been guilty of doing this too, but from experience with an angine like this in a mini a sudden 28psi boost spike with your foot down when your only expecting 10psi can have you in the wrong lane before you can blink.
