Home > A-Series EFI / Injection > MPI inlet manifold question.
Andymini
Member #: 438
London
Picked up an MPI inlet manifold the other day. Just wondering what some of ports were used for on the original set-up. Planning on modding the intake ports for 4x injectors and using this with a 1293 turbo engine with mirage exhaust manifold and T2.
1.-
2.-
3.-
4.-
5.-
6.- Idle air control valve?
tmsmini
Member #: 7637
Fremont California
1. Can't remember with outlooking
2. Brake servo
3. Breathers, emissions, purge valve
4. Breathers, emissions, purge valve
5. Inlet air temp
6. MAP sensor
With 3 and 4 I am not sure which one connects to which with out looking and I am at an airport at the moment.
1. Fuel pressure regulator reference
Chalkie
Member #: 9764
Northamptonshire.
Its hard to weld in to take four injectors
Paul S did it I belive
