Page: |
Home > A-Series EFI / Injection > MS3 question | |||||||
33 Posts Member #: 9867 Member |
10th Jun, 2016 at 09:38:39am
Apologies if this is a dim question but I've a got a megasquirt 3 and plan to use it for just the ignition side of things for now, I plan on going injection at a later date.
10th Jun, 2016 at 11:32:52am
Yes you can use MS3 for ignition alone.
10th Jun, 2016 at 12:34:09pm
As Paul says, TunerStudio is the only sensible option when working with anything Megasquirt.
10th Jun, 2016 at 01:27:10pm
Cheers guys!
10th Jun, 2016 at 02:16:19pm
On 10th Jun, 2016 Smackfiend said: You could well be correct there, I held off buying the paid version for ages after the historical change from Megatune but, once you go to fuelling, you will find the paid for version invaluable.
I've had a look at generating my own map using the engine parameters and I think I need the paid for version not the freebie one (Tuner Studio MS lite), is this the case? If you want to wait before upgrading, typing it in manually is no big deal. But the table sizes may be different (16x16 vs 12x12 possibly?) so you may have to do a bit of interpolation to make it fit properly. That's where importing/exporting to a spreadsheet becomes useful. Schrödinger's cat - so which one am I ??? |
Page: |
