Page: |
Home > Technical Chat > running and set up problems | |||||||
54 Posts Member #: 11135 (Not "TurboDave" - He is TurboDave16v) Halstead, Essex |
6th Jun, 2016 at 07:02:31pm
Today, 07:33 PM
2742 Posts Member #: 637 Post Whore Hertfordshire |
6th Jun, 2016 at 07:26:30pm
I think you could be right about the lack of heatshield
My build thread..
6th Jun, 2016 at 07:33:13pm
I'll make a heat shield for it tomorrow and give it another try. I have taken it out again for another try and whilst keeping moving it doesn't give any problems and goes like a rocket. As soon as traffic got heavier and airflow was reduced was when it started playing up. It certainly sounds heat shield problem to me |
3074 Posts Member #: 1348 Post Whore wakefield West Yorks |
6th Jun, 2016 at 08:07:10pm
check your fuel ? do you have an inline filter , could that be blocked
Edited by cossierick on 6th Jun, 2016. |
4626 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
6th Jun, 2016 at 08:08:07pm
Get a heat shield on there, and if you still have issues make a solid jet holder to replace the bi-metallic standard item.
6th Jun, 2016 at 08:08:08pm
I have removed the filter and the problem is still there |
6th Jun, 2016 at 08:10:31pm
Thanks turbo Phil. I'll give that ago if I have no luck with the heat shield. What gauge steel should I use for it? |
6th Jun, 2016 at 08:21:24pm
Same thickness as the centre strip is as standard. 0.8mm or so iirc ?
109 Posts Member #: 10368 Advanced Member Australia |
7th Jun, 2016 at 07:22:02am
not sure of the Hif needle/seat mechanism - but basically is it big enough to cope with flow? - ie it starves itself until it can catch up |
3004 Posts Member #: 2500 Post Whore Buckinghamshire |
7th Jun, 2016 at 11:25:13am
Just because your AFR is 18 does not necessarily mean it is running weak.
Site Admin 15300 Posts Member #: 337 Fearless Tom Fenton, Avon Park 2007 & 2008 class D winner & TM legend. |
7th Jun, 2016 at 12:01:43pm
Rig up a fuel pressure gauge so you can see what happens when it dies off. Could it be the old gauze on the tank strainer issue?
2094 Posts Member #: 9894 Post Whore Dorking |
7th Jun, 2016 at 12:45:59pm
What ignition you using? |
21st Jun, 2016 at 08:57:34pm
Made a heatsheild and got it fitted. Gave it another try over the weekend and it seems to have sorted it. Done just under 100 miles down the a12 and back roads constant driving without a hitch |
Page: |
