Page: |
Home > General Chat > what running and thrust clearance on primary gear? | |||||||
21st May, 2016 at 09:48:01am
having some trouble with oil in the clutch housing the thrust was at about 8 thou and the running clearance about 4 thou
21st May, 2016 at 10:07:02am
i should say that its straight gears on a 1098cc and that the seal was a good aftermarket one also that there was a crack in the clutch casting near the idler bearing pocket but with all that said honestly i believe the gear clearances are to blame and im willing to have the crank ground and new bushings turned pressed n reamed to the best clearance to stop this oil mess from destroying another clutch and costing more cash and hassle
Page: |
