Page: |
Home > How To > List of essentials required for a turbo conversion | |||||||
Site Admin 8506 Posts Member #: 16 Sold the turbo and seeing what the C20XE can do! Near Lincoln |
9th Jun, 2003 at 03:21:28am
Just thought i best compose a little list really Edited by iain on 17th Jun, 2003. |
Site Admin 6277 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
9th Jun, 2003 at 05:11:33am
Don't forget some decent fuel line. |
9th Jun, 2003 at 05:30:28am
8mm inside diameter for both feed and return is recommended by many and what i have used on mine. |
38 Posts Member #: 18 Member |
9th Jun, 2003 at 09:48:10am
I found a MPI tank solved all my fueling problems. Highly recomend it! Edited by FesterTurbo on 9th Jun, 2003. |
10 Posts Member #: 21 Just Registered! |
9th Jun, 2003 at 05:38:41pm
MPI Tank is a very good mod when convertin to a turbo |
12 Posts Member #: 44 Member |
2nd Jul, 2003 at 08:00:08am
I must say the "turbo box" option does not convince me at all. God knows how much the torsional stress of the bodyshell is affected after you chop the crossmember in half. Also on LHD cars then you almost have no place for the brake and clutch master cyls.
2nd Jul, 2003 at 09:04:27am
Sounds like a pretty good alternative to the T3. Cheers |
3rd Jul, 2003 at 12:14:27pm
I have a water cooled T2 in my van. all i did was mod the metro manifold.
24th Jul, 2003 at 03:03:20pm
2 Posts Member #: 70 Just Registered! |
6th Sep, 2003 at 01:56:38pm
MirageMotorsports sells an interesting kit to fit the Garret T2, as found in Renault 5 GT turbo. The nice thing is that the smaller turbo gives a more progressive torque delivery, and ultimately, more "usable" power and torque. Also the R5GT Turbo "Phase2" already included water cooling for the turbo housing - particularly interesting in a Mini! One question: this kit is to fit a Garret T2 in a Metro Turbo engine, or to fit a T2 in a "normal" 1275 mini engine? Thanks, Marc |
4625 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
6th Sep, 2003 at 05:50:57pm
As the engines are exactly the same, bar differences in pistons etc, then the kit will fit either engine.
7th Sep, 2003 at 05:28:09pm
and with a normal A engine, I need a diferent distributor for the turbo? |
7th Sep, 2003 at 09:25:31pm
You can use your existing dizzy, but the advance curve will need to be altered to suit the Turbo engine.
1 Posts Member #: 186 Junior Member |
3rd Mar, 2004 at 03:51:07am
where would you get all the mini turbo stuff from if I live in Austalia |
11 Posts Member #: 248 Member |
21st Apr, 2004 at 12:14:43am
where would you get all the mini turbo stuff from if I live in Austalia yeah, same. im in tassie and would love to find out more about turbocharging my mini GT. does anyone have a walk-through of everything that needs to be done, with pics etc...? cheers, josh MINI CLUBMAN GT
4436 Posts Member #: 164 The Stig.. Newport Pagnell |
21st Apr, 2004 at 12:31:50am
i am quite sure someone could muster you together all the bits needed and mail them..
439 Posts Member #: 176 Pre-op Transvestite Felixstowe, Suffolk |
21st Apr, 2004 at 12:40:37am
If ur not too fussed about the cash side of it i'm pretty sure www.minispeed.co.uk could provide you with everything you need and also do a worldwide delivery service NO LONGER A <3 lover of BOLT-ON plastic <3 .... (and DOUBLE proud of it) |
21st Apr, 2004 at 02:45:55am
many thanks ppl... ill let u know how I go!!!
MINI CLUBMAN GT
5 Posts Member #: 253 Junior Member |
26th Apr, 2004 at 11:43:05am
Another Aussie on the boards.....
2742 Posts Member #: 637 Post Whore Hertfordshire |
22nd Jan, 2006 at 12:56:07am
what would you need to do to a normal 1275 to turbochare it?
My build thread..
Page: |
