Home > For Sale > Job lots- seat rail kits, harness points, titanium parts etc
topcat
Member #: 9408
Tiptree, Essex
Hi guys, due to work taking up 95% of my time and wife and baby taking up the other 5% I need to make some space and clear out my old project parts.
I've priced them as batches but would really appreciate someone buying the entire lot, I'm sure I am losing money and there is a lot to be made.
Seat mounts- I used to sell them for something like £35 per kit (cheap price) comprising of 2 tubes, 4 end plates and 4 brackets. It's the most expensive 1" CDS tube and all brackets are 3mm laser cut, nuts are 16mm square EN3b IIRC and some are drilled and tapped some are blank. I'm guessing there are 150 brackets, maybe 150 nuts (some tapped), approx 100+ spreader plates and 19 tubes. £300
The harness mounts are my own design, 3mm laser cut with 7/16 UNC captive nuts to suit the standard wind in eyelets for harnesses. 50-100 of, all folded, some welded. £100
I have some aluminium water pump brackets for a second engine steady that are less obtrusive than the horrible "ultimate" ones, they need folding but fit lovely. I'll get a picture of the one I fitted. £50
Just under 100 (I've used 4) 2mm laser cut aluminium door hinge spacers/washers, I didn't want to do away with them so had a batch made up to save weight (don't pretend we're not all obsessed with saving weight everywhere we can!) £50
Around 10 CNC milled aluminium coilpack mounts, I still love these- they look great, I also have a whole load of aluminium tube spacers to mount them with, and some of the bolts required. They are machined and tapped ready for use. Also a couple of towing eye brackets, MSA spec but a little overkill. £100
Titanium goodies- There are rear handbrake levers that require cleaning and bolting together (M6 dome head does the job nicely with a nylock), door stops (use the standard steel springs either side of the titanium bits), the funny shaped levers and triangles are there for door opening straps/wires for those who want a really minimal door handle. There are also door handle brackets, require a strap/band between them, and aluminium door lock end plates. £100
All this adds up to £700, I'd accept £600 for the entire lot, that's only the cost of about 15 of the seat mounts sold at £40 each so hopefully it is a good deal for someone and it means I get some space back!
Collection ideally from Tiptree, Essex, or I can palletise and ship to UK for about £50. I'm not sure if messaging has to be done on this thread but if anyone wants to text or ring me please use 07793132360.
Thanks,
TC
www.topcatcustom.co.uk
jonny f
Member #: 9894
Dorking
If you want to split I will define talk take the ti rear handbrake levers etc.
topcat
Member #: 9408
Tiptree, Essex
I should have made a load more Ti brake levers as they would have done very well!
Thanks for the messages etc, still hoping to sell the job lot but if not I'll consider splitting.
jamestar
Member #: 9159
Devon
Did anyone ever buy any of this? After some stuff to make some weld in seat rails
jonny f
Member #: 9894
Dorking
PM'd him and got nothing back.
MatthewPettitt
Member #: 9237
Banbury
I'm after a pair of weld in seat rails kits.
By the look of it topcat has stopped selling the kits individually??
Is there a good alternative that anyone can suggest? (with the larger/ square nut, thicker brackets etc.)
thanks, Matt
I think Rally Design sell something very similar mate
jamestar
Member #: 9159
Devon
You can get hold of TC on the mobile number in the first post :)
