Home > Technical Chat > Engine question
TurboDave
Member #: 11135
(Not "TurboDave" - He is TurboDave16v)
Halstead, Essex
With London to Brighton just over a week away my turbo has gone and needs a rebuild to stop it passing oil through the seals. This won't be back in time to do the run. Can I remove the turbo and fit a standard carb and lab manifold to get it going again? Would it run as a low compression engine ok without the turbo bits? Compression ratio I'm using is 8.5:1.
Thanks
It will work. It may feel a bit flat due to the low compression, but it will still be driveable.
Phil.
yep, infact you van leave the same carb on there, I seem to remember somone swapping off the exhaust and turbo, and just whacking a filter on the turbo side of the intercooler.
TurboDave
Member #: 11135
Halstead, Essex
Ok. Thanks for replies. I had a set of twin hs4 on the car before I turboed it. Would they take some of the flatness away over a hif44. I have both but want to make it as driveable as possible while my turbo is away
I wouldn't bother with the twins they won't make it any better. Just stick an exhaust manifold on it and a filter on the intercooler like Joe says for now.
I would imagin theres been engine changes since the twins were on ( lower CR, different cam) so it will probably run like crap on them,
the HIF I would expect to be much closer, as all your doing is running the same engine off boost (as it would most of the time anyway)
Go the easy route!
TurboDave
Member #: 11135
Halstead, Essex
Ok. I'll just go with the same carb. Thanks for your help
nobody have a spare turbo knocking about ?
Nick
Member #: 154
Midlands
ran like it for a couple of weeks for some reason I can't remember any more
Ultimate cold air feed.
Remember that one on eBay? Had an intercooler in the inner wing with an air filter on the end going staight into the inlet.
I think it was turbo too.
Ah! it was Nick! LOL
