Page: |
Home > General Chat > Baulk rings, which to use? | |||||||
6th May, 2016 at 07:03:24pm
I know there's a few threads on this, but none are recent enough.
6th May, 2016 at 07:20:57pm
The latest cnc machined ones from MS are supposed to be very good.
6th May, 2016 at 07:27:17pm
Minispares say to use their CNC baulk rings with their gear sets. If I were using a standard gear set then I'd use good used ones. If something is worth doing, it's worth doing half of. |
224 Posts Member #: 9987 Senior Member Amsterdam |
6th May, 2016 at 08:49:19pm
Minispares/Keith Calver used to say use our competition baulk rings, 10x better than the Rover items, special this...special that...you'd be a fool to use anything else.
![]() 696 Posts Member #: 10034 Post Whore Birmingham |
6th May, 2016 at 08:57:51pm
I always save a stack of the original ones out of any box I strip. No point throwing out 3rd and 4th gear ones with next to no wear. |
4307 Posts Member #: 1321 Post Whore Wiltshire |
7th May, 2016 at 12:41:27am
Minispares super duper ones, or good used ones. There doesn't seem to be a middle ground. On 7th Oct, 2010 5haneJ said:
7th May, 2016 at 06:32:37am
On 6th May, 2016 John said:
If I were using a standard gear set then I'd just not use any. He he he we know ![]() ![]() Yes i moved to the darkside |
![]() 64 Posts Member #: 6668 Advanced Member |
11th May, 2016 at 03:41:09am
Funny this has come up i have been using genuine rover ones and last year i got twenty for upcoming builds. Anyway when i started to use them there were four or five that were out of spec. i like to use them with .065 to .070 gap when on the cone of the gear. A couple were machined so much they were 0 gap and a couple had .090 or more. I have in my shop a five speed with a completely worn out second gear syncro and it was new and now has less than a thousand miles! it would grind into second on the first day he ran it. Check them when you install them. Aaron Racecar spelled backwards is Racecar |
Page: |
