Page: |
Home > Wanted > 13 | |||||||
2nd May, 2016 at 10:22:41pm
As above looking for some 4x4/4x101.6 13" wheels for the r100 (converted to 4x101.6) Edited by Paul R on 27th May, 2016. Drives
11th May, 2016 at 06:35:02pm
Bump Drives
23rd May, 2016 at 08:05:03am
None? I remember when there used to be loads for sale Drives
23rd May, 2016 at 08:47:45am
long ass away to freight em but ive got a set of 13x6 that i doubt ill put back on the car ive grown to like the fat sidewall |
23rd May, 2016 at 10:45:26am
erm arnt the R100's a different PCD? On 28th Aug, 2011 Kean said:
10020 Posts Member #: 1456 Mongo Barnsley, South Flatcapshire |
23rd May, 2016 at 11:40:34am
Yep Joe they are. If something is worth doing, it's worth doing half of. |
23rd May, 2016 at 11:58:40am
24th May, 2016 at 07:45:56pm
Correct from factory they aren't 4x4 they are 4x3.75, but it is now 4x4 all around as using mini rear hubs and alloy drums and re-drilled front hubs.
Edited by Paul R on 24th May, 2016. Drives
24th May, 2016 at 11:59:00pm
yeah they have 175/55R13 on them
6729 Posts Member #: 618 Post Whore Glasgow |
25th May, 2016 at 12:46:52pm
4x4 pcd info would have helped at the beginning, not R100!. I've been watching wheels for metros and completly ignored all the 14" 4x4 ones that could well have done you on the assumption you were running R100 spec.
On 24th May, 2016 Paul R said:
Correct from factory they aren't 4x4 they are 4x3.75, but it is now 4x4 all around as using mini rear hubs and alloy drums and re-drilled front hubs. Shame you are in aus, I like big sidewalls as well 185/60 r13 I will be using. |
27th May, 2016 at 08:09:55pm
Edited. Drives
Page: |
