Home > For Sale > Sell Up! Everything Must Go! Updated 13/10/16
I've done a very silly thing and bought a Ford Capri 2.8 injection so to prevent the boss from murdering me I am selling up my mini stuff.
Feel free to PM me offers on items/multiples, worst I can say is no and if the pricing of anything is a mile out please let me know!
MK1 Austin Pressed Grille
As per pictures, has 2 notches cut out for bonnet straps not really visible when the moustache is on and washers welded on for the included Smithy's bits buttons.
https://c2.staticflickr.com/6/5475/30262065...624b512a9_b.jpg
https://c1.staticflickr.com/9/8411/30297489...85157258e_b.jpg
https://c1.staticflickr.com/9/8272/30211805...64e137725_b.jpg
https://c2.staticflickr.com/6/5708/30181421...7dec8546f_b.jpg
https://c2.staticflickr.com/6/5459/30297039...35c97fabc_b.jpg
£55 posted
Intercooler Hose Kit
This was used to fit a 2wd cossie intercooler in the grille area of my clubman when using a T3 and a Nic/Fusion Fabs style plenum. 2 x 45 degree 51mm alloy bends, 2 x 51-60mm joiners to fit cossie cooler and a 90 degree and 45 degree silicone hose. All clips included needs a really good clean.
£20 posted??
Alloy Oil Catch Can
https://c2.staticflickr.com/6/5277/30146365...0ba3ea570_b.jpg
https://c2.staticflickr.com/6/5785/30117073...b2d963e3d_b.jpg
£15 posted
3.5mm steel manifold spacer, used this to stop me having to shave the back of my block down when using a T2 with large compressor housing on a mirage manifold
https://c1.staticflickr.com/9/8397/30035902...85576fcf8_b.jpg
£10 posted
Metro Thermostat housing x 2
https://c1.staticflickr.com/9/8129/29491479...b85b64a96_b.jpg
https://c1.staticflickr.com/9/8420/29491837...3ee43e06e_b.jpg
£6 each posted
8.4" Drive Flanges with studs
https://c2.staticflickr.com/2/1683/26238978...8e97e0832_b.jpg
£15 posted
Timing Gear Cover with breather
https://c2.staticflickr.com/2/1544/26561128...8bfafb6ec_b.jpg
£20 posted
Gearstick
https://c2.staticflickr.com/2/1541/26561180...673a1f2fe_b.jpg
£15 posted
John Cooper Signed Moto-Lita Steering Wheel & Cooper Gearknob
Steering wheel is in good overall condition with a few marks here and these (you can see a mark on the leather in the picture) commensurate with its age.
The gearknob had a crack on the enamel badge but is still presentable.
The wheels are pretty rare to find in good condition these days and Minisport sell them for over £400!
https://c2.staticflickr.com/2/1562/26419514...41b10d4fe_b.jpg
https://c2.staticflickr.com/2/1587/26239005...1c4fb2e26_b.jpg
£250ono the pair (I'd prefer collection/meet as I wouldn't want it to get damaged in transit but can post if needs be)
Injection Front Subframe
In fair condition
https://c2.staticflickr.com/2/1577/25958239...48d33d10e_b.jpg
£30 collected
Injection Gear Selector/Linkage
https://c2.staticflickr.com/2/1692/26288237...7684383dd_b.jpg
£10 collected
Pair of driveshafts
Outer CV's should be good to go
https://c2.staticflickr.com/2/1490/26535160...d722a70a5_b.jpg
£10 collected
Long Driveshaft
https://c2.staticflickr.com/2/1520/25956138...3749d71bd_b.jpg
£5 collected
Steering Rack
Looks a bit tatty but was perfectly functional when removed from my SPI
https://c2.staticflickr.com/2/1611/26561155...507bedbee_b.jpg
£10 collected
Sold
AEM Wideband Gauge
As per pictures has had a Smiths chrome bezel grafted on this has removed the usual screw fascia so not reversible. Looks a lot more at home in a mini dash like this in my opinion. The wire to the wideband sensor has been cut and was joined with a plug (visible in the pictures) to get it through bulkhead this will either need re-joining or the plug replacing. The gauge has about 5k usage but the sensor only has about 2k usage so plenty of life left in it. I've also got a lambda boss and bung to go with it.
https://c2.staticflickr.com/6/5777/30295900...4e59fb9cb_b.jpg
https://c2.staticflickr.com/6/5698/30180358...798bb9f2f_b.jpg
£80 posted
DSN RetroSport Oil Filter Head with temp sensor hole (new)
https://c2.staticflickr.com/8/7576/30120372...f27b9864a_b.jpg
£50 posted
Lower front nearside engine steady and uprated bushes
https://c1.staticflickr.com/9/8136/29492100...5d40940a6_b.jpg
£15 posted
GT17 Gasket kit
https://c2.staticflickr.com/2/1694/26266782...afa9edc3f_b.jpg
£5 posted
GP A Dump Valve and Silicone Hose
https://c2.staticflickr.com/2/1554/26485840...29ce7fca5_b.jpg
£15 postedSold to Chalkie
DSN RetroSport Small Waterpump Pulley Silver (new)
https://c1.staticflickr.com/9/8772/30005504...63294688c_b.jpg
£33 posted Sold to clubman91
DSN RetroSport Thermostat Housing Spacer (new)
https://c1.staticflickr.com/9/8820/30035941...a7d1e5f4a_b.jpg
£25 posted Sold to clubman91
Modified 1275 A+ Turbo Block
Standard bore 1275 A+ Turbo Block (ready for boring)
Modified by Carl @ Force Racing for:-
Oil fed thrusts (the new oil fed 1/2 of the thrusts and countersunk screws are included I used the other half on another engine)
Zetec oil jets (or you can insert a helicoil and use BMW oil jets)
Centre main bearing cap modified for a CMS (strap included and I will throw in the set of TurboDave16v mains bolts)
drilled for 11 stud
Oil gallery plugs removed and tapped for removable hex plugs
Block
https://c2.staticflickr.com/2/1533/26495094...3c123615c_b.jpg
https://c2.staticflickr.com/2/1657/26288249...817ec5328_b.jpg
Bolts
https://c2.staticflickr.com/2/1541/25908916...8c3b993ef_b.jpg
https://c2.staticflickr.com/2/1444/26485834...f54a6d21c_b.jpg
£200 collectedSOLD
Rebuilt A+ Gearbox with 3.44FD (needs a nose bearing)
As per picture (casing has been painted black)
https://c2.staticflickr.com/2/1623/26535136...1402925df_b.jpg
£150 collectedSOLD to Chalkie
Wok
https://c2.staticflickr.com/2/1643/26535162...9e256a6b4_b.jpg
£10 collected SOLD to Chalkie
Metro Turbo engine for rebuild
Genuine turbo engine on standard bore, head and gearbox.
No ancilleries or flywheel/clutch.
Engine and box turns over freely and may run if put together but I would recommend a rebuild.
Picture below of how it is now.
Engine number starts 12HA85AA so should have a CAM6581 crank, 3.2FD and large nose bearing transfer housing.
https://c2.staticflickr.com/2/1465/25956158...017bdc737_b.jpg
https://c2.staticflickr.com/2/1503/26710545...220b8ef16_b.jpg
https://c2.staticflickr.com/2/1503/26172196...c4c780b54_b.jpg
£350ono (As per the picture collected)Sold to Tim
ARP 11-Stud Cylinder Head Stud Set
Torqued twice in total and includes a new sachet of lube
https://c2.staticflickr.com/8/7316/26845745...1692e18a6_b.jpg
£75 postedSold to Tim
In car adjustable 3-leg bleed valve
https://c2.staticflickr.com/8/7666/26845747...c73a1ce31_b.jpg
£10 postedSold to Tim
New Unused 190mm Organic Verto Performance Clutch Plate (C-AHT594)
Fitted to my RTS but never ran (no box) - These are £74 + post from minispares and currently out of stock.
https://c2.staticflickr.com/8/7394/26516409...bb7a2033e_b.jpg
https://c2.staticflickr.com/8/7370/26721646...c814c0572_b.jpg
£45 postedSOLD
GT1752 Turbo
In very good condition apart from the fact I ham fistedly bent a fin on the compressor wheel when I had the housing off to modify it for fitment to my manifold, I have a new replacement compressor wheel that I will include.
I had begun modifying this for usage on my GT17 manifold so have cut the actuator bracket off it (cut-off included as per pics).
Replace the compresspr wheel and you are good to go!
https://c2.staticflickr.com/2/1657/26447329...4ab58f590_b.jpg
https://c2.staticflickr.com/2/1521/26473585...d3c33518d_b.jpg
£90 postedsold
GT1752 Turbo
In fair condition, there is a little play however I have a rebuild and I've got a rebuild kit to include with it.
This turbo is unmodified and original.
https://c2.staticflickr.com/2/1668/25934683...781c30bd1_b.jpg
https://c2.staticflickr.com/2/1531/26447324...b968cf890_b.jpg
£90 postedsold
Rebuilt Turbo Carb
1k use since rebuilt and a high boost spring installed
https://c2.staticflickr.com/2/1498/26683965...841ed5c1e_b.jpg
https://c2.staticflickr.com/2/1466/26683964...64a35e4cb_b.jpg
https://c2.staticflickr.com/2/1495/26173736...9df214dd0_b.jpg
https://c2.staticflickr.com/2/1473/26504913...710b0bb84_b.jpg
https://c2.staticflickr.com/2/1460/26710504...3675496b7_b.jpg
Sold
Malpassi Fuel Pressure Regulator
1000miles usage (bracket included but I'll be pulling the hoses off)
https://c2.staticflickr.com/8/7593/26287378...5fb805a3d_b.jpg
£35 postedSOLD
Protech lowered rear alloy shocks
https://c2.staticflickr.com/2/1530/26445684...2441274c8_b.jpg
£75 posted Sold
Short Turbo Engine - ~1000 miles since build
1293cc +20 Omega 10cc cast pistons (20thou deck height)
Balanced A+ conrods with ARP rod bolts
Standard grind CAM6581 turbo crank. Polished, measured and balanced (by EDA) prior to installation
Centre Main Strap with Finnings CAT HT bolts and hardened washers.
All new bearings including cam bearings
Lightened cam followers
Avonbar Phase 2 Cam
Swiftune adjustable timing gear
"Genuine" Powerflow Turbo oil pump bought from Avonbar about 10 years ago
Proper cast impellor water pump.
Flat breather timing cover.
All oil gallery plugs pulled and replaced with hex plugs
All core plugs replaced
Block was tank cleaned prior to machine work being carried out (by drakes in bradford)
As it is now:-
https://c2.staticflickr.com/2/1522/26266777...fb6f1cf3f_b.jpg
https://c2.staticflickr.com/2/1687/23994280...45fa67bd9_b.jpg
Pictures during build:
https://c2.staticflickr.com/6/5480/90803232...8dfc630c6_b.jpg
https://c2.staticflickr.com/8/7301/90860800...2c90d2ecd_b.jpg
https://c2.staticflickr.com/6/5458/90860830...215cf4a04_b.jpg
Engine had immediate oil pressure on startup and held good hot idle oil pressure so no issues with the oil pump
The Gearbox, Tom Fenton crank damper and sensor bracket and oil fittings are not included but the dizzy bung will be left in.
I will include a standard crank damper however which I have spare
£750 collected SOLD
Modified Turbo Head
Orignally started life as a Minispares MSE3 head but was reworked by BENROSS to have 28cc chambers and significant additional porting work.
It also sports 30mm exhaust valves (hardened seats suitable for unleaded), double springs, inner spring locators etc.
Powered the worlds fastest metro van (sic) to a 13.9 up the strip and 175bhp on 17psi of boost on the rollers.
Done approx 2000miles since BENROSS reworked and reconditioned the head with new valves, guides, springs etc and the additional porting.
https://c2.staticflickr.com/2/1690/26447325...fbcb94ea0_b.jpg
https://c2.staticflickr.com/2/1450/24326899...d62d5921f_b.jpg
£425 collected SOLD
Rebuilt SC/CR Gearbox with 3.2 FD (no differential) 1k use
Minispares Clubman Gearset
All new bearings (All genuine)
Central Oil Pickup
Blasted gearbox casing
Blasted turbo transfer casing with new bearing and race installed
helical transfer gears (including primary & idler)
(gearbox still attached to engine so can be seen in pics above)
£550 collected SOLD
Pre-Verto Wok with Clutch Arm, Plunger and Release Bearing
https://c2.staticflickr.com/2/1657/26511860...f924bde95_b.jpg
https://c2.staticflickr.com/2/1487/26445759...057ec193e_b.jpg
£20 (collected) SOLD
Blue Bailey Dump Valve
https://c2.staticflickr.com/2/1635/26511773...e73bcfebb_b.jpg
£40 posted SOLD
Powerlite Pre-Engaged Hi-Torque Starter
Approx 1k usage
https://c2.staticflickr.com/2/1510/26445688...67fa5f938_b.jpg
https://c2.staticflickr.com/2/1647/26238959...6563eb8ea_b.jpg
£100 posted SOLD
KAD 3/4 Rear Anti Roll Bar Kit
Approx 1k usage
https://c2.staticflickr.com/2/1649/25906918...ab53da948_b.jpg
https://c2.staticflickr.com/2/1506/26511784...ee52a3cee_b.jpg
£120 SOLD
Rebuilt Disc Brake Hubs with steering arms (roller bearing type bearings)
These were fitted to an abandoned project then have been in a box for a few years suggest clean and re-grease. One ball joint nut and spring washer missing.
https://c2.staticflickr.com/2/1462/26511808...268eff2ce_b.jpg
£80 postedSOLD
Nic Stainless Plenum
https://c2.staticflickr.com/2/1469/25936748...4062f4bd1_b.jpg
£120 posted Sold to Ryan C
Rover Inertia Fuel Cut-Off Switch and Plug
https://c2.staticflickr.com/2/1719/26445664...47eda8bec_b.jpg
£10 posted Sold to Mini Mole
https://c2.staticflickr.com/2/1610/26419447...e55df263c_b.jpg
https://c2.staticflickr.com/2/1502/26445677...f4946c6aa_b.jpg
£12 posted Sold to Kezz
Genuine MK1 Steel Boot lid (as per picture)
https://c2.staticflickr.com/2/1493/26419509...4088dff77_b.jpg
https://c2.staticflickr.com/2/1542/26511836...e16b18ca9_b.jpg
£120 (collected) Sold
Pair of Genuine Timken Taper Roller Front Wheel Bearing Kits (Halfords NOS Stock)
https://c2.staticflickr.com/2/1683/26485881...8068a8cd8_b.jpg
https://c2.staticflickr.com/2/1446/26445727...b305ab95a_b.jpg
£65 posted Sold to Matt
Turbo Carb Abutment Plate
https://c2.staticflickr.com/2/1590/26238980...3894d643c_b.jpg
£20 posted Sold to Toad
MPI Chrome Gearstick
https://c2.staticflickr.com/2/1556/26445728...7b336309c_b.jpg
£25 postedSold
Front Disc Brake Hubs with steering arms for Rebuild
https://c2.staticflickr.com/2/1450/25906895...a405d860f_b.jpg
£50 posted SOLD
RTS clutch
Built by Sprocket with 1275 & 998 spring on Minispares lightweight steel verto flywheel and brand new 190mm performance clutch plate.
Assembly has been balanced
https://c2.staticflickr.com/2/1471/26266852...cce3ea23b_b.jpg
https://c2.staticflickr.com/2/1601/26513752...4cb139ea0_b.jpg
£250 posted Sold to Nick W
Exhaust hangers and poly bushes (fitted but never ran)
https://c2.staticflickr.com/2/1468/25906880...3d3eb3196_b.jpg
£15 posted Sold to Jonny
As new, fitted as a test due to suspected fault but was a carb issue.
https://c2.staticflickr.com/2/1574/25908903...928a47c8f_b.jpg
£35 posted Sold to Stancemods
KAD Rack Limter Kit
https://c2.staticflickr.com/2/1642/25908889...59f0340da_b.jpg
£10 posted Sold
10 Row 115mm Oil Cooler
1/2 BSP fittings (approx 30 miles use before I stripped car)
https://c2.staticflickr.com/2/1624/26445684...3d6cfcc56_b.jpg
£35 posted (I'll throw in rubber mounts if I can find them) Sold
Quaife ATB (pot joint usage) with 3.2 FD - 1k use
(still in gearbox attached to engine so no pics)
£550 collected Sold
Cooper SPI Leather Gear Gaitor
https://c2.staticflickr.com/2/1628/26485832...9ecdf36aa_b.jpg
£12 posted Sold
Matty (Fusion Fabrications) GT17 Manifold, Downpipe and Turbo Inlet Manifold
Inlet has been slimmed down to suit the thickness of the exhaust manifold.
Servo fitting will be removed from inlet as I need this for another engine.
https://c2.staticflickr.com/2/1526/26266912...40cbb75f5_b.jpg
https://c2.staticflickr.com/2/1445/25934682...55b7f42d1_b.jpg
£380 posted Sold
Lightweight round nose bonnet hinges
https://c2.staticflickr.com/2/1546/25973453...05d8db0e2_b.jpg
£15 posted SOLD
NOS Hardy Spicer Pot Joints (NOT HS Couplings)
https://c2.staticflickr.com/2/1625/25908969...75232fc90_b.jpg
https://c2.staticflickr.com/2/1486/25975519...bf20f294c_b.jpg
£75 posted Sold
1275 Transfer Case (with breather hole)
https://c2.staticflickr.com/2/1714/26468813...b19152c21_b.jpg
£20 collectedSOLD
New Genuine Metro Turbo 1st Motion Nose Bearing ADU6033 (Large Type)
https://c2.staticflickr.com/2/1649/26485823...a95574725_b.jpg
£40 postedSold
DSN RetroSport Transfer Case Breather - 5/8 (used)
https://c1.staticflickr.com/9/8138/30120014...d116ef054_b.jpg
£12 posted
Metro turbo carb spacer
https://c2.staticflickr.com/8/7721/30005906...2ecd5a035_b.jpg
£4 posted
Goodridge braided verto clutch hose kit
https://c2.staticflickr.com/6/5006/30085470...685345851_b.jpg
£12 posted
New Mini Sport Adjustable Tie Rods Pair
https://c2.staticflickr.com/2/1482/26419443...28ee27a45_b.jpg
£20 posted
Edited by John on 7th Nov, 2016.
stancemods
Member #: 10019
Manchester
PM sent about the fuel pressure regulator.
Reserving the KAD limiter kit while i look through the rest of the list
Tempted with the shocks. Do you have the fronts?
Pm on its way
Edited by Sprocket on 19th Apr, 2016.
On 26th Oct, 2004 TurboDave16v said: Is it A-Series only? I think it should be...
On 26th Oct, 2004 Tom Fenton said: Yep I agree with TD........
steve w
Member #: 1917
AKA chargedzetec
Do you have coilover brackets? I need the hub/ball joint end of the kit
Just the rear shocks Colin. Sorry Steve no coilover bits
FPR and Rack limiters sold
Callum
Member #: 10396
Stoke-on-Trent
Pm sent
jonny f
Member #: 9894
Dorking
I'll take the exhaust brackets and the mains bolts (if they're for CMS, if not just the brackets). PM me details.
I'll take the inertia switch please.
On 7th Oct, 2010 5haneJ said: yeah I gave it all a good prodding
More added.
you are a bad man. I'm tempted..........
Yo-Han
Member #: 3228
North of the Netherlands
Tempted by the RTS; any chace you are going to the IMM to save on postage cost?
Dazed and Confused....
Be tempted!
On 20th Apr, 2016 Rob Gavin said: you are a bad man. I'm tempted..........
I am afraid not. I doubt a budget courier will be too expensive.
On 20th Apr, 2016 Yo-Han said: Tempted by the RTS; any chace you are going to the IMM to save on postage cost?
Edited by John on 20th Apr, 2016.
Toad
Member #: 10162
West Sussex
I'll take the turbo carb abutment plate please. PM me details
cheers
MatthewPettitt
Member #: 9237
Banbury
Hi John,
I'll take the matty manifold. pm'd
philc
Member #: 1346
bromsgrove
have you got any adjustable engine steadies?
Yo-Han
Member #: 3228
John, you have a PM
JT
Member #: 637
Hertfordshire
On 21st Apr, 2016 philc said: have you got any adjustable engine steadies?
If John hasn't give me a pm. I have a few spare..
My build thread..
Possibly some lower ones
Some cracking prices there mate, almost wish i was in the market lol
This vtec mofo is about to cost me dearly for last 2 bits
Yes i moved to the darkside
Updated:-
I've yet to price and photograph but I've also got:-
Rebuilt helical box with 3.4 FD
1275 block machined for oil fed thrusts & zetec jets
Another gearstick
Injection front subframe
Set of driveshafts
Long driveshaft
1275 transfer case & wok
big valve 12g940 for reconditioning
Turbo engine, head & box (missing ancilleries, flywheel, wok, crank damper & timing chain tensioner) turns over freely but I would advise rebuild. Should have 6581 crank & 3.2 FD in it.
Steering rack - looks tatty but worked fine when removed from my spi
2 x A+ DAM5625 box for rebuild with 3.44 FD
Injection gear selector and rods (longer)
There will also be a few more bits coming off the car but I won't put up for sale until they are off.
Matty Manifold Sold
baker_boy
Member #: 9226
Rushden
The box and modified head are very tempting. The head would be reunited with his old friend actually! Hmm...
i got nothing but time..
Minski
Member #: 10654
Northampton
Pm,d you John
Users viewing this thread:
none. (+ 2 Guests)
Next ->
