Page: |
Home > Beginners Tech > How a bov works? | |||||||
32 Posts Member #: 10958 Member |
17th Apr, 2016 at 07:54:31pm
Just wondered what actually raises the piston/diaphragm. Is it the vacuum drawing it up or the boost pressure pushing it up?
Edited by HUBBA.HUBBA on 17th Apr, 2016. |
3004 Posts Member #: 2500 Post Whore Buckinghamshire |
17th Apr, 2016 at 08:06:30pm
The vacuum. |
17th Apr, 2016 at 08:33:05pm
Depending upon the type, both act together. On 26th Jan, 2012 Tom Fenton said:
18th Apr, 2016 at 05:01:34am
In most piston / diaphragm types its a bit of both
Yes i moved to the darkside |
18th Apr, 2016 at 07:25:41am
yep, on most valves if the little pipe comes off it wont have boost pressure helping it stay closed and it will start dumping, mine does this around 15psi. On 28th Aug, 2011 Kean said:
18th Apr, 2016 at 05:02:48pm
Thanks for the responses. Is there anything available that just works off the boost pressure without the need of the vacuum pipe? I would like to limit boost to 10psi, I already have a bypass valve for when the throttle is closed. Or could a normal bov limit the boost with the throttle fully open? Cheers |
Page: |
