Page: |
Home > Technical Chat > Dry Deck, K-head - Thread sizes | |||||||
4304 Posts Member #: 1321 Post Whore Wiltshire |
16th Apr, 2016 at 05:26:08pm
Turning my attention to preparing the block for the conversion, I was wondering if anyone had a diagram or list of thread sizes.
11046 Posts Member #: 965 Post Whore Preston On The Brook |
16th Apr, 2016 at 06:55:02pm
I used a combination of 1/8" and 1/4" taper thread plugs in brass and iron On 26th Oct, 2004 TurboDave16v said:
16th Apr, 2016 at 06:59:03pm
Oh, and for the head studs a heave duty Bridgeport with an end mill rather than drill will get better results, but the threads can still scew depending on how the holes are tapped On 26th Oct, 2004 TurboDave16v said:
1391 Posts Member #: 1686 Post Whore Oxford |
18th Apr, 2016 at 11:47:38am
As for drilling. Dont use an end mill.
OMG Robert that's a big one |
18th Apr, 2016 at 07:35:25pm
112 Posts Member #: 10125 Advanced Member Zoetermeer, The Netherlands |
26th May, 2016 at 06:58:13pm
For metric fans: I managed to use M8, M12 and M14 in brass and cast iron (old cam shaft interior).
Edited by Streetscreamer on 26th May, 2016. |
8297 Posts Member #: 408 Turbo Love Palace Fool Aylesbury |
26th May, 2016 at 09:11:44pm
On 18th Apr, 2016 Sam said:
As for drilling. Dont use an end mill. Spot drill. Small twist drill Slot drill twist drill to size. A bridgeport is an not a bad tool to do it on. You can align it correctly and put in the relevent grid pattern more accutately. Ideally you want to forget using a jacobs chuck and use collets. You missed off thread milling after the twist drill. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
Page: |
