Home > General Chat > Reg number not correct for mini van year.
fixitphil2
Member #: 10945
scarborough/ northyorkshire
Iv just bought another mini. A van to restore, on the logbook it's down as a 1964 850 mini van but it's a 998 with rubber subframe mounts so it's a 1976 onwards van. I not sure if I should update log book or put an 850 in and restore to 64 spec. It will be having a new front end anyway as its rotten.
I wouldnt worry about it. So long as Insurance knows.
D4VE
Member #: 10749
lowestoft suffolk
I didnt think the vans changed there design apart from the roof? Its not a clubby estate with van plates is it?
Nothing gets past Dave lol
Callum
Member #: 10396
Stoke-on-Trent
The vans and pickups changed with the saloons they just kept the side panels the same for the external hinges. So the changes like the rubber mounted subframe and exhaust tunnel from remote to rod type all happened at the same time as other minis
Edited by Callum on 11th Apr, 2016.
A mate had a 66 van that had been re-shelled with an old stock late model shell back in the early 80's, (assumed after the end of production) which had similar details to yours. It certainly explained the variations. Can't confirm with this one but nothing to say it hasn't happened here too
He had his fully restored by Mini Machine back in the day and the only real obvious signs were the single bolt front frame and the lack of roof vent. He had the floor changed to suit the earlier year
Edited by Rob Gavin on 11th Apr, 2016.
Sounds like its a ringer to me, someone has got hold of an early logbook and swapped it over to get free tax on a later van.
I'd be keeping fucking quiet about it if I were you, especially to the DVLA unless you want a Q plate.
fixitphil2
Member #: 10945
That's what I am worried about Tom, I did a hpi it says it's a 1964 , 850 van but the engine number on the hpi is a 99h
I'm sure it won't be the only mini with dubious ID. I'd keep quiet about it and anyone asks you bought it like that and don't know the history (true).
D4VE
Member #: 10749
lowestoft suffolk
Yeah just play dumb n enjoy your free tax
