Page: |
Home > How To > Ballast resistor - Yes or No? | |||||||
60 Posts Member #: 629 Advanced Member Colchester |
12th Sep, 2005 at 05:34:47pm
Why is their a ballast resistor fitted in the fuel pump power supply to the MG Metro Turbo and the ERA Mini Turbo, after all it's a 12v pump fitted into a 12 supply? |
12th Sep, 2005 at 06:30:29pm
no one bothers!
AlexF |
Forum Mod 1322 Posts Member #: 28 Post Whore Milton Keynes |
13th Sep, 2005 at 12:15:19am
True no one bothers - but if the engine is only developing 90bhp - then the fuel pump is wasting energy pumping an excess amount of fuel through the system.
9317 Posts Member #: 59 First mini turbo to get in the 12's & site perv Herefordshire |
17th Sep, 2005 at 09:44:05am
i was reading a jap magazine and one of then had a raditor install under the seat to cool the fuel
1300 Posts Member #: 829 Post Whore essex |
11th Feb, 2006 at 05:58:16pm
what if you run the pump ballast resister on the fuel pump and fit a pressure switch on the plenum chamber so when on boost the switch bypass the resister for full pump out put on the pump 1293 Turbo mini
2521 Posts Member #: 417 Post Whore Swindon |
11th Feb, 2006 at 06:16:16pm
I tested my fuel pressure last week and it was 4psi with ballast resistor and with out,will leave it there as its quieter.....well till I get 20psi boost pressure then will change it to 12 volt
Page: |
