Home > General Chat > value of engine
miniminor63
Member #: 672
The oversills police
Oslo, Norway
Difficult question I know, but here goes. Pleae help with valuation of long Block as below
A series Block bored 73.5 mm
SA 1071 crank with 70.2 mm stroke on 020/010 (bladed, wedged, tuffrided, balanced, crossdrilled by MED). giving total volume of 1191 cc.
lightened and polished A rods with ARP bolts, normalised and balanced
powermax 73.5 mm pistons.
Calver ST RE13OT camshaft.
Swifty adjustable Duplex timing cover
cylinder head ported by Vegard and professional with 35.7/29 mm valves
1.3 rockers of A series type that has been welded for strength
25D distributor matched to camshaft.
Ultralight flywheel and lightened Cooper S backplate, Orange diaphram
engine has covered 1500 km since being built.
LCB to match will follow, but no carbs, starter, radiator, alternator or gearbox will follow.
Edited by miniminor63 on 5th Apr, 2016.
I would guess it would be around the value of a comparable 1380 engine.
miniminor63
Member #: 672
Oslo, Norway
Thanks for the reply. What the going rate for good 1380s then these days? Trying to decide if I should put it on the shelf or sell.
I'd guess £1500 ish for the lot, It is quite specialist though, so could fetch more. Especially if someone was looking for an engine for a 1071 car, as I assume is using an a-series block.
