Page: |
Home > Introduce Yourself > Drop gears | |||||||
3 Posts Member #: 11345 Junior Member |
5th Apr, 2016 at 01:44:40pm
Hi everyone, my name is Rod
5th Apr, 2016 at 01:50:58pm
AFAIK the experiments never made it into production, and they just went with a larger bearing on the bottom transfer gear in the transfer housing, ( but most of us dont bother with this larger bearing anyway)
5th Apr, 2016 at 02:27:27pm
Ahha, just what I had been thinking, thank you, I won't go there! The extra lube sounded like a good idea at the time! This particular vehicle has only been in my possession for a short while and I definitely need to rebuild to solve a serious oil pressure problem. While it's in pieces I'd like to take it to 125 to 130 hp with a bit of head work, new Pistons and a little more boost!
3588 Posts Member #: 655 Post Whore Northern Ireland |
5th Apr, 2016 at 05:32:31pm
130hp wont even trouble helical drop gears.
7265 Posts Member #: 1268 The Boom Boom speaker Police! Essex |
5th Apr, 2016 at 06:06:28pm
You can't use 1.5:1 ratio rockers with a standard head. The valve springs will bind. In the 13's at last!.. Just |
6th Apr, 2016 at 02:16:48am
Thank you for the input, it looks like I need to spend a little more on the head than was planned! Is there a set amount that needs to come out of the head to lower the valve springs? |
1750 Posts Member #: 10190 Post Whore belgium |
6th Apr, 2016 at 05:39:14am
Do you need 1.5? Always under the impression that 1.3 was en ough with a turbo engine. you can do anything if you set your mind to it...
6th Apr, 2016 at 09:42:57am
I'm not a fan of 1.5 rockers. If you're binding the springs with them, your cam already has plenty of lift, so not needed IMO.
On 5th Apr, 2016 Joe C said:
the standard drops are pretty resilient, if you use the later MPI ones and bearings they can take over 200 hp. Joe, is there anything different about the design of the MPI ones, or just a chance materials choice? And for that matter, could the MPI gearbox internals also be stronger? |
6th Apr, 2016 at 11:30:38am
On 6th Apr, 2016 coastlines said:
Thank you for the input, it looks like I need to spend a little more on the head than was planned! Is there a set amount that needs to come out of the head to lower the valve springs? You dont lower the valvesprings LOL You fit new more suitable valve springs. 9.85 @ 145mph
Page: |
