Page: |
Home > General Chat > Modifying a gt1752 | |||||||
74 Posts Member #: 11056 Advanced Member South yorkshire |
31st Mar, 2016 at 10:20:18am
Just bought a gt1752 off eBay, got to modify it abit to get it to work, had to drill the holes out as the studs are on the manifold but one is too tight to get the nut on the back, and the actuator is gonna need spinning to the opposite side, has anyone had these problems before? If so have you got any pictures of what you did to overcome it? |
31st Mar, 2016 at 08:06:02pm
The easiest way is it to remove the studs from the turbo and fit them into the manifold threads, then relieve the turbo like this to fit a nut. The housings will need rotating to your required position, as they sit differently to the Saab position. Depending on how you have the compressor housing positioned to suit the hose plumbing an actuator bracket needs to be made to suit. Hope this helps?
Edited by matty on 31st Mar, 2016. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
31st Mar, 2016 at 09:19:23pm
Yes mate that's sound thanks! Only problem I've got is I've already drilled the threads out of the turbo so I can use the studs on the manifold like a idiot! So I've got no option then to chop a bit out on the turbo! |
3004 Posts Member #: 2500 Post Whore Buckinghamshire |
1st Apr, 2016 at 05:52:30am
Do any of these pics help ?
1st Apr, 2016 at 05:53:57am
To get clearance for that nut I just "eased" the turbo casting with the angle grinder |
1st Apr, 2016 at 06:53:57am
Ryan. Just to be clear, the photos the Tadge44 has posted are modifications to fit a GT17 to Metro turbo manifold.
In the 13's at last!.. Just |
1st Apr, 2016 at 09:19:05am
Thanks Gary - this old bugger is steadily getting more senile, daily. |
1st Apr, 2016 at 09:26:03am
Ye I do have a matty manifold, just gonna have to knick a little bit out with the grinder! And change the place of the actuator! |
1st Apr, 2016 at 02:24:36pm
On 1st Apr, 2016 tadge44 said:
Thanks Gary - this old bugger is steadily getting more senile, daily. Your memory is still probably better than mine ;-/ In the 13's at last!.. Just |
Page: |
