Page: |
Home > General Chat > my first panel beating | |||||||
![]() 1137 Posts Member #: 1450 Post Whore Near Paris - France |
19th Mar, 2016 at 09:03:07pm
ys,
Rusty by nature
They said "That sounds rough mate." I said "Cheers it cost me a fortune to make it sound like that!" |
19th Mar, 2016 at 10:07:33pm
To be honest i dont think you will find many people that would put swages like that into panels with a hammer anyway. I couldn't do much better! |
3004 Posts Member #: 2500 Post Whore Buckinghamshire |
19th Mar, 2016 at 10:30:22pm
I have a friend who does this sort of thing all the time - but he has a steel form made first and then uses a pneumatic hammer.
20th Mar, 2016 at 06:59:58am
I hamered it on my vice and some wood blocks african style really but I wonder if it's the application where you need a sand bag ? Rusty by nature
20th Mar, 2016 at 10:53:03am
Hard wood blocks as a former sounds just right to me. Usual problem when we start out metal forming is trying to move the metal too quickly. Light blows repeated often and moving around to persuade the metal rather than forcing it usually works best. |
20th Mar, 2016 at 10:56:13am
Just had a thought. Were you using shaped pieces of hardwood to dent the alloy or had you formed a block with the x shaped grooves in it to panel beat the metal into the grooves ?
20th Mar, 2016 at 07:14:00pm
I hammered down the metal in a slot between wood blocks but honestly no clamping what so ever, did it African style on the floor ...
Rusty by nature
![]() 696 Posts Member #: 10034 Post Whore Birmingham |
20th Mar, 2016 at 08:45:54pm
I'd make the form from plywood: rectangle base with triangle sections glued and screwed on so as to leave the recessed area. Don't hammer directly on the metal, but get a 50mm section of rod, something like an old gudgeon pin or square bar, and hammer that into the metal. Round off the rod's ends slightly. Move the metal piece after each hit. It may also help to tap a flange over each side of the form and also screw the edges down, but I'd be tempted to try without first. |
20th Mar, 2016 at 10:06:44pm
Cheers mate, will get to that level of preparation if I ever get to do a part that needs to be shown Rusty by nature
3591 Posts Member #: 655 Post Whore Northern Ireland |
21st Mar, 2016 at 10:02:47am
Always amazed at the skill of this guy for some home alloy fab.
![]() 2975 Posts Member #: 10749 Post Whore lowestoft suffolk |
21st Mar, 2016 at 01:49:41pm
Am thinking of making a form/plug of a rear parcel shelf n beating ali into it to make a replacemement On 24th Oct, 2015 jonny f said:
Nothing gets past Dave lol NOTHING GETS PAST ME!! ![]() 1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
21st Mar, 2016 at 08:28:30pm
Ask Paul W he maybe happy to help he is a genius Drives
Page: |
