Home > Wanted > 5/8 36 spline coupler
Long shot but anyone got one they would like to part with?
http://www.justkampers.com/00-3142-0-empi-...for-j33540.html
I put an order into just campers a month ago and at the time it said nothing about waiting 90 days!
I'm sure a mini rack is 5/8. can't you cut the female spline off the bottom of a mini column as they are splined all the way through. I had to do this on a se7en rack to fit a UJ
Edited by matty on 19th Mar, 2016.
Yes what Matty said, as I found this out the other week, if you cut it and put it in your lathe and turn just the weld off it comes off and leaves something like what's in your pic.
Thanks chaps, i will see if i have a spare.
I'll have a look at work to see if we have any but most are 1"+
