Home > 998cc > Double bushed drop gears
PJW1986
Member #: 11330
Dorset
Hi all,
A few years back now I remember somebody had a few bushes made up for fitting 1275 drop gears to a 998. Are these bushes still around or does anybody have access to the correct measurements for machining one up as I have access to full workshop tooling.
Thanks in advance
Paul
slater
Member #: 1291
Suffolk / Birmingham
http://www.minimania.com/Primary_Gear___Bu...eplacement_1142
That article appears to give the finished sizes/clearance. Not sure if the bushes your thinking of were floating or not but shouldn't be hard to make one with that info?
PJW1986
Member #: 11330
Dorset
I was going to make mine press fit but I'm sure I can come up with something now I have a starting block. Thanks
Edited by PJW1986 on 8th Mar, 2016.
