Home > Technical Chat > Denso Alternator & Required amps.
alaskanow0
Member #: 8466
Mansfield
I'm currently looking at small denso alternators for the micra project. I need something this size, but will 40/45amp be really be enough power.
It's will have to run
Mpi tank
Ecu
Injectors
Cool pack
Lights
Stereo & small amp
Stack dash
Heated screen
tadge44
Member #: 2500
Buckinghamshire
With lights and heated screen on I reckon it might run close.
Isn't a there a 55-60amp version?
Yes, I had a 60amp one that I sold at bingley recently.
alaskanow0
Member #: 8466
Mansfield
Well I've just bought a new denso 40amp for £40, so I'll see how it goes. It's good to know I could upgrade to the 60amp version if need be.
I'll just have to be careful and not run everthing all at once. I'm fitting the biggest battery available due to running 11.6-1CR.
t3gav
Member #: 229
Gavin@minispares.com
kent
Where did you find one that cheap? Prices seem to have shot up on these :(
jonny f
Member #: 9894
Dorking
Anyone have a link to 60a one?
alaskanow0
Member #: 8466
Mansfield
eBay, guy had bought it but never fitted it.
My 40amp was not really up to task last time around, so this time I have gone for a 60amp just so your awear its bigger in size.
i cant remember if mine was a 45a or a 65a now, but i do know with
fuel pump,
ecu,
coil,
laptop,
lights,
fans..
( also water injection 10+a on its own)
its was too much at idle, but i didnt have them all on at once and when on the move sorta 2krpm+ it kept stuff topped up
i did however have a 50 some Ah battery
i seem to remember your gonna use a small Ah battery....you sorta need enough amps from the alternator all the time imo
jonny f
Member #: 9894
Dorking
I definitely need to go up on mine. At idle with everything on its really pulling it down.
I have,
fuel pump
megajolt
fan
electric water pump
koso dash
3x gauges
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
i believe the denso one on have is a 60A seems to be up to snuff but ive also got a red top optima battery that really dose have some balls to it altho its heavy as fuck
im running the norm stuff + spot lts
ecu, coils, dual fans, fuel pump, IC water pump, normal lights, 2x130w spots + 2x60W floods on with 60w high beams i use them quite often at night as im out in the sticks just the lights if ive got the lot going is 42A its probaly close to 60A with everything electrical tuned on at once id guess but since its not all on at once it seams to cope
AWDmoke
Member #: 713
Western Australia
Why not just use the Micra denso alternator?
Should be more than up to the job as the Micra has all the electronics you have (and more), and you can pick them up for under 12 quid
http://www.ebay.co.uk/itm/NISSAN-MICRA-MK2...S8AAOSwQPlV8G9p
