Home > General Chat > Powerfile belts
Where is the current best place to get them? still ebay?
I bought a stack of new old stock belts (about 100) although a few are a bit perished so can't be used, I got those off ebay and I think they cost me about £30-£35
graemec
Member #: 1424
Carnforth, Lancs
These seem OK - delivery is about £6 and they are the right 451mm length
https://bndabrasives.co.uk/sanding-belts-ba...pack-of-50.html
Edited by graemec on 21st Feb, 2016.
nimbusprint
Member #: 11290
I have a cheapo belt sander which uses 457mm belts, I snapped my last powerfile belt one day and out of desperation I cut a spare belt into 12mm strips, hey presto! and you get a better choice of grit grades. The spring loaded end of the powerfile is just enough to tension slightly longer belt.
Ian
jonny f
Member #: 9894
Dorking
B&D abrasives sell correct length power file belts. Big packs nice and cheap and they are Norton.
graemec
Member #: 1424
Carnforth, Lancs
That's who I was talking about in my above post, but forgot the link!
Edited now so the link is there.
Callum
Member #: 10396
Stoke-on-Trent
I always use abtec abrasives for my belts and flap wheels. The aluminium oxide 451mm belts work out at £40 Inc delivery for 100, cheaper if you buy more. They do zirconia belts as well but only 457mm
http://www.abtec4abrasives.com/13mm-x-451m...elts-3408-p.asp
Tupers
Member #: 9441
South Devon
I've been using these on my pneumatic belt sander recently and they've lasted as well as the branded 3M belts I had perviously.
http://www.ebay.co.uk/itm/13-x-457mm-Sandi...ar=451004247326
