Page: |
Home > Technical Chat > Shaft loadings, | |||||||
19th Feb, 2016 at 02:43:06pm
Chaps,
1030 Posts Member #: 1291 Post Whore Suffolk / Birmingham |
19th Feb, 2016 at 03:05:56pm
The bending load on the shaft will do i think as your feeding the forces in further down. There definately a lot more bending moments happening on the shaft and pulley.
2909 Posts Member #: 83 Post Whore Glasgow, Scotland |
19th Feb, 2016 at 03:09:23pm
it depends on the coupling between the green part and blue part. if the coupling is like a point load then the lower one has twice the force on the bearing (to skale) if we asume a rigid coupling and assume the blue bar is perfectly rigid then they will be the same. Real life will probably put the actual result somewhere between these two cases turbo 16v k-series 11.9@118.9 :)
9502 Posts Member #: 1023 Post Whore Doncaster, South Yorkshire |
19th Feb, 2016 at 06:31:16pm
in my eyes the bearing loadings will be the same
Yes i moved to the darkside
20th Feb, 2016 at 07:56:16am
id say the bearing load is the same if there is two bearings on the shaft
20th Feb, 2016 at 09:57:05am
The greater distance to the pulley mount on the shaft will mean you will see more bending moment at that bearing for the same belt/chain tension. What will complicate things is that the dished pulley (especially if really offset) will also be trying to twist on the shaft, giving rise to all sort of other forces, some of which may cancel the increased bending moment.
510 Posts Member #: 1592 Smart Guy! mainland europe near ze germans |
20th Feb, 2016 at 02:06:33pm
Bending load at pully connection to shaft is greater but the force at the bearing is the same as the arm is shortened That sir, is not rust, it is the progressive mass reduction system
Page: |
