Page: |
Home > Technical Chat > Roller SC drop gears | |||||||
52 Posts Member #: 11169 AKA: Smegmium Derby, ish |
4th Feb, 2016 at 10:03:05am
I have been advised by MED that for a high power build (>130bhp) I should really use their Roller bearing sc drop gears instead of the normal pin type.
"If its not broke, whack a turbo on it"
1434 Posts Member #: 8466 Post Whore Mansfield |
4th Feb, 2016 at 10:26:42am
Normal pin should be fine on SC drops as it reduces the side load on the shims anyway. As long as you replace the idle bearings and shim them correctly.
Edited by alaskanow0 on 4th Feb, 2016. Class C 3rd Place Avon 2011 14.18 @101mph |
4th Feb, 2016 at 10:27:37am
never really seen a problem with the idler bearings personally. On 28th Aug, 2011 Kean said:
4th Feb, 2016 at 10:34:41am
Ok, just realised your doing YouTube build.
4th Feb, 2016 at 10:48:17am
Yep - so its a 1310, 10cc omegas, with "the head"
On 4th Feb, 2016 alaskanow0 said:
Ok, just realised your doing YouTube build. "If its not broke, whack a turbo on it"
4th Feb, 2016 at 12:04:37pm
What gearbox are you going to be running? Class C 3rd Place Avon 2011 14.18 @101mph |
4th Feb, 2016 at 12:25:49pm
Initially a standard one, but will be upgrading to SC as and when cash allows.
11046 Posts Member #: 965 Post Whore Preston On The Brook |
4th Feb, 2016 at 12:33:39pm
There's evidence on Minispares of a helical cut roller idler gear for A+ gear case which uses the old cooper s tooth profile. They also do a matching primary gear with floating bush.
9502 Posts Member #: 1023 Post Whore Doncaster, South Yorkshire |
4th Feb, 2016 at 07:44:09pm
the straight cut whine is the thing i miss the most about the a series Yes i moved to the darkside
4th Feb, 2016 at 07:52:45pm
thats jolly interesting,
On 4th Feb, 2016 Sprocket said:
There's evidence on Minispares of a helical cut roller idler gear for A+ gear case which uses the old cooper s tooth profile. They also do a matching primary gear with floating bush. Not yet available! On 28th Aug, 2011 Kean said:
4th Feb, 2016 at 10:30:35pm
hmm.......... choices choices...!!!
Edited by Turbonator on 4th Feb, 2016. "If its not broke, whack a turbo on it"
4th Feb, 2016 at 10:41:56pm
http://minispares.com/product/Classic/Engi....aspx|Back%20to On 26th Oct, 2004 TurboDave16v said:
144 Posts Member #: 10557 Advanced Member |
5th Feb, 2016 at 04:38:48pm
Had the roller s/c med drops in since 2011 no probs they are quiet on idle ...no clattering but definately a bit louder on the whine......ive just learnt to tune them out i suppose......switzerland,italy,kent,lithuania...etc
Edited by smokestack-lightning. on 6th Feb, 2016. Double-Blind experiment, N:
2974 Posts Member #: 10749 Post Whore lowestoft suffolk |
5th Feb, 2016 at 06:31:41pm
Roller have a louder whine? I want some! The whinier the better imo On 24th Oct, 2015 jonny f said:
Nothing gets past Dave lol NOTHING GETS PAST ME!! 1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
5th Feb, 2016 at 06:46:42pm
Helical drops all the way. Nothing like slipping it into fourth and crusing in relative silence
5th Feb, 2016 at 08:12:14pm
On 5th Feb, 2016 Sprocket said:
Helical drops all the way. Nothing like slipping it into fourth and crusing in relative silence anyone building a weekend car that can cruse in relative silence needs a serious reality check !! Yes i moved to the darkside
5th Feb, 2016 at 08:45:05pm
With helical drops, can you put dowels into the aluminium casings to pin the thrusts in place? So instead of the thrusts spinning and munching up the casing, the idler would spin against the thrust surface instead. |
5th Feb, 2016 at 09:03:55pm
Helical drops all the way. Nothing like slipping it into fourth and crusing in relative silence anyone building a weekend car that can cruse in relative silence needs a serious reality check !! On 24th Oct, 2015 jonny f said:
5th Feb, 2016 at 09:24:09pm
Helical drops all the way. Nothing like slipping it into fourth and crusing in relative silence anyone building a weekend car that can cruse in relative silence needs a serious reality check !! That's ok then code that car comes out during the week too. Stealth is the key my young padawan learner Edited by Sprocket on 5th Feb, 2016. On 26th Oct, 2004 TurboDave16v said:
5th Feb, 2016 at 09:30:43pm
Helical drops all the way. Nothing like slipping it into fourth and crusing in relative silence anyone building a weekend car that can cruse in relative silence needs a serious reality check !! That's ok then code that car comes out during the week too. Stealth is the key my young padawan learner Even though i tryed for a stealth theme you won hands down because ive never seen your mini And I think you hit the nail on the head, your just getting old hahaha Yes i moved to the darkside
5th Feb, 2016 at 09:56:22pm
On 5th Feb, 2016 PhilR said:
With helical drops, can you put dowels into the aluminium casings to pin the thrusts in place? So instead of the thrusts spinning and munching up the casing, the idler would spin against the thrust surface instead. I opted for something completely diferent I think doweling the thrusts to the case will only highlight the real issue. The thrusts dont normally spin on the case, therefore, the real problem is when the gear grabs the washer. On 26th Oct, 2004 TurboDave16v said:
Page: |
